Home > Technical (L322) > Icarsoft DPF regeneration
JoshVogue94
Wales 2011 Range Rover Vogue 4.4 V8 Santorini Black
Has anyone managed to get the icarsoft to do an active regeneration on their car? I've got the red dpf full light on the dash but everytime I try and activate the regen through the icarsoft it just kicks me out.
Post #644516 1st Oct 2022 8:54pm
garyRR
Just an obvious note that it's only to be completed once the cause of the DPF filling is resolved.
Also tried a motorway run to see if it will self re-gen? 2015 Range Rover Autobiography 4.4 SDV8
Post #644524 1st Oct 2022 9:57pm
JoshVogue94
Yes mate there was a split in one of the intake pipes which I've replaced. I've tried taking it on a run but it won't regen as it's showing a soot level of 33 on the live data.
Post #644528 1st Oct 2022 10:37pm
jordon0
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
i have managed to do regens with an i carsoft
needs to be up to temp but the i carsoft will let you know when you can do it normally takes around 4 miles to get the regen properly going and you can watch the soot value drop
Post #644545 2nd Oct 2022 8:38am
JayGee
Also make sure there are no other engine related fault codes as this can prevent regeneration. This is from the workshop manual
"If, due to vehicle usage and/or driving style, the active regeneration process cannot take place or is unable to regenerate the
DPF, the dealer can force regenerate the DPF. This is achieved by either driving the vehicle until the engine is at its normal
operating temperature and then driving for a further 20 minutes at speeds of not less than 30 mph (48 km/h)."
 2012 TDV8 Vogue (L322)
Post #644569 2nd Oct 2022 1:28pm
Baltic Blue
The very common PO40D-00-(2F) EGR fault code definitely doesn’t prevent Forced Regens with the Gap iid.
Post #644572 2nd Oct 2022 1:51pm
JoshVogue94
Still no luck today with the regen. Wondering if I need to tell the car the dpf has been replaced before it will allow the regeneration because of the red warning light?
Post #644583 2nd Oct 2022 6:36pm
JayGee
DO NOT do this. It resets the estimated ash load and the whole regen process will be messed up. 2012 TDV8 Vogue (L322)
Post #644584 2nd Oct 2022 6:39pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
make sure you have over 1/4 tank of fuel too.
also have you updated to the latest version of software for IcarSoft? 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #644664 3rd Oct 2022 5:14pm
Jayk69
https://www.jaginfo.org/threads/icarsoft-forced-dpf-regen.109748/ 2012 Vogue 4.4 TDV8 - Current
Post #644665 3rd Oct 2022 5:18pm
JoshVogue94
Tried again today, updated the icarsoft and still no luck had communication failed coming up when trying to do the regen. Wondering if I put a cleaner through the dpf will it get the soot content down enough for me to clear the codes and get the dpf triangle from red to yellow so that I can take it on a run to regen
Post #644937 6th Oct 2022 6:03pm
Baltic Blue
You should seriously consider buying a Gap iid.
I can assure that it will complete a Forced Regen and clear your soot level down from 33g to single figures and at the same time clear the Red DPF fault and the restricted performance visit dealer message.
It is very easy to use and will pay for itself in no time .
Mike.
https://www.fullfatrr.com/forum/topic60984.html G reg 2.5VM Vogue Portofino red 1991- 1999
Post #644961 6th Oct 2022 8:21pm
DrRob
What Mike said Bow down Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #644978 7th Oct 2022 2:20am
jordon0
i carsoft can clear red dpf and force regen as i pointed out 6 month before gap decided to allow people to do this it can be done just seems lile there is some issue
the iid is all singing and dancing but also a chunk of money in the fact that mine sits in glove box just waiting to be used
Post #644979 7th Oct 2022 3:21am
JoshVogue94
Hi guys bit of an update...
Sent the diagnostic log off to icarsoft to see why it won't allow the car to regenerate and waiting for them to get back. Used a local garages diagnostic tool that said the soot content is above 60g and the dpf needs to be replaced. Can't see how it's that high as since the red light came on the car basically hasn't moved and is showing 31g on the icarsoft live data.
Just wondering wether the GAP IID will definitely allow me to do a forced regeneration without the warning of too much soot in the DPF or will I need to purchase a DA-DPF dongle as suggested in another post to reset the soot count
Post #645537 13th Oct 2022 11:08pm
