Home > Maintenance & Mods (L322) > 4.4 TDV8 EGR and DPF removal |
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 |
What's updated? |
23rd May 2022 11:08am |
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 139 |
My sig. Cam 2011 TDV8 Vogue in Stornoway Grey |
23rd May 2022 7:16pm |
Oh, nice 👍 |
23rd May 2022 7:29pm |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 419 |
up to what year can you remove/blank off the egr ? |
24th May 2022 2:27pm |
I had a boost leak that must have been developing for a while (short pipes going into donut) that I sorted and the common fuel sender fault that meant I had to time it right to get the fuel level low enough to fix. That's all now been done and I've just gone through a full tank of fuel (don't do lot of miles) and got the fuel warning after 560 miles. I have noticed that fuel consumption is very good most of the time, but does increase significantly for no apparent reason and I can only assume is the dpf regenerating. It does this a lot and I'm starting to consider whether I should have got that mapped out too. I didn't think it should been engaging so often and really thought it would be a rare occurrence. I should note that I created an egr blank and blocked that off in case it was leaking. Cam 2011 TDV8 Vogue in Stornoway Grey |
20th Jul 2022 9:27am |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 |
I may be late to the party here but I just spoke to my indy, who states that you can program the EGR permanently shut and then program the engine management to completely ignore the EGR. The DPF can be kept as is and should be fine.
18th Aug 2022 8:58am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 820 |
he is right Sir
13th Sep 2022 1:02am |
Sorry I didn't notice your reply jackie-o.
13th Sep 2022 4:53pm |
RRABNara Member Since: 02 Mar 2022 Location: SW3 Posts: 31 |
Will it be possible and make sense to blank the EGR, but leave the DPF on 4.4 TdV8?
27th Sep 2022 5:21pm |
Well yes, that's just what I've done and described. Cam
28th Sep 2022 6:39pm |
Chrali Member Since: 13 Apr 2017 Location: Norwich Posts: 122 |
I'm feeling the urge to make my 4.4 TDV8 a better drive, as I find it way too annoying. (yup I bought the wrong car). I'm still unclear if its safe to map out the EGR as part of a remap? Is there any change in emissions with the EGR mapped out, that could affect an MOT aka fail? Also has anyone had a remap and regretted it? Encourage alternative fuels, use all the petrol!
29th Sep 2022 8:25am |
I´m wondering the same thing.
29th Sep 2022 8:37am |
Well maybe I can add more and clarify this discussion.
30th Sep 2022 9:57am |
Thanks telly-addict if my L322 doesn't sell I'll heading down this route Encourage alternative fuels, use all the petrol!
30th Sep 2022 12:59pm |
