Home > Maintenance & Mods (L322) > 4.4 TDV8 EGR and DPF removal
Page 6 of 14 <123 ... 567 ... 121314>
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
My point is that not all things are equal and while many areas of engineering are black and white, there is a middle ground or grey area where judgement is needed.
Analogy time again and for this I will assume you're a) a male under 80 and b) been to a Kart track at least once in your life; a trip to any commercial Kart track will offer the chance to race against your friends and see just who if the fastest. But is the outcome of your race purely down to your skill..? What of the Karts - they are all the same make with the same chassis and engines and varying ages, maintained the same as much as possible. Cam
2011 TDV8 Vogue in Stornoway Grey
Post #625021 28th Feb 2022 5:13pm
JayGee
Sorry you have lost me...
The topic was concerned with removal of the EGR valve and DPF from the TDV8 4.4 engine - can this be done and does it improve performance or fix any problems. From all the evidence I've seen it's no to all 3. 2012 TDV8 Vogue (L322)
Post #625022 28th Feb 2022 5:18pm
telly-addict
Cam-Tech-Craig wrote:
But a remap is something quite different DT..... Neutral
Hi Craig, where can I get a set of EGR blanks for the 4.4? I've looked in the usual places and only see the 3.6 ones, are they the same? (Just got an '11 4.4) Cam
Post #625779 9th Mar 2022 11:29am
DrRob
Nobody sells them. It seems from a lot of reading that 4.4 should be left alone but I’m no engineer Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #625789 9th Mar 2022 12:47pm
JayGee
Shouldn't be difficult to make your own. The EGR inlet is easy to access on the left side of the intake. There is only one EGR valve on the 4.4. You will need to remove the throttle plate otherwise the ECU will try to shut the intake to create negative pressure to overcome low EGR gaslfow. Good luck...... Whistle 2012 TDV8 Vogue (L322)
Post #625795 9th Mar 2022 2:12pm
telly-addict
It's getting a remap which deletes the EGR in software. I just want to physically blank them as well. Cam
Post #625816 9th Mar 2022 4:03pm
telly-addict
Good one Thumbs Up Cam
Post #625818 9th Mar 2022 4:04pm
JayGee
AFAIK a 'software EGR delete' still allows it to function during startup and DPF regeneration so maybe physically blanking it may not be wise unless you are also having the DPF removed? 2012 TDV8 Vogue (L322)
Post #625823 9th Mar 2022 4:42pm
telly-addict
I was thinking about it, but not feeling the urge just yet. Cam
Post #625830 9th Mar 2022 5:43pm
GraemeS
The EGR valve gets closed during DPF regen, not opened and the exercising after the engine has stopped doesn't require any gas flow. If EGR is mapped out to never open while the engine is running then best to blank the tube in case of valve leakage.
I will never remove mine's throttle butterfly as mine is required for my runaway protection which closes the butterfly for a short period at engine switch-off. A fault code for the 3.6 indicates that its ecm will close its butterflies for unexplained engine operation but I haven't found any evidence that the 4.4 does the same.
Post #625850 9th Mar 2022 7:52pm
DrRob
Empire Tuning in Colchester will EGR and DPF delete via software. Chap on Overland 4WD YouTube had it done Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #625852 9th Mar 2022 7:56pm
DrRob
This guy
https://youtube.com/channel/UC-TUHvdGeYYzG9mBvJH1jjQ Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #625854 9th Mar 2022 7:58pm
telly-addict
Cheers Rob.
I got the remap with EGR delete. The DPF will still regen as and when required, but should be much less often with the EGR no longer in use. Interestingly enough, the remap has removed the P040d fault code (EGR temp sensor A) and unsurprisingly the fuel consumption has improved dramatically. The engine note changed too and is much quieter now.
All in all, quite happy with the result. Cam
Post #626104 13th Mar 2022 8:31pm
DrRob
Your foot note says you have a 2008 tdv8 so no DPF anyway or have you not updated it.
Confused dot com Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #626105 13th Mar 2022 8:33pm
telly-addict
Updated Whistle Thumbs Up Cam
Post #632632 23rd May 2022 9:50am
