![]() | Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2644 ![]() ![]() |
Excellent! |
That makes sense - I was thinking more along the rate of change / longevity of change but wasn't sure if there needed to be a centre point registered as some sort of reference. |
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 107 ![]() ![]() ![]() |
I just needed the latest version and they appeared, Pat did advise me to go to the 'ID Tool config' and 'Find ECUs' first and see if they appear after that, mine didn't so I did the update. all good now ![]() Previous 2007 BMW M5 E60 |
I will do a test on a road that has some speed bumps and turns on it before I change the sensors and then Ill do the same again with the new sensors as thats a good idea and may be helpful for others ![]() My theory on how the ADM recognises the calibrated height - an its just a theory - is that the calibration mode for the adaptive damping takes its reading from these sensors when you run the calibration for Adaptive damping, I could be completely wrong though and im sure someone with a better understanding will correct me on this. 2012 TDV8 Autobiography Baltic Blue Previous 2007 BMW M5 E60 |
Adaptive damping doesn't use its height sensors for vehicle height information, only for suspension movement. They don't need to be calibrated as a static value is what is required to detect that the suspension isn't moving whereas the suspensnion ecu needs to know when the corner is at normal height so needs to be told (calibrated) beforehand. |
So, I have fitted four new height sensors.
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Thats good news!
This was the part on mine that was seized, I had a look at freeing it up and it freed up ok with some gentle persuasion, the collar is rubber so pops off easily when freed off, once cleaned up the bolt wasn't round and it was a very loose fit when re-assembled
It would be a good idea to put something like Calcium grease on the spigot to prevent water ingress and provide lubrication. Personally I wouldn't recommend a metal-loaded grease (for much, certainly not for keeping water & muck out). Even if there is no current issues, it will prevent issues further down the line.
Just had front upper and lower arms and rear toe arms replaced and a 4 wheel hunter alignment. The car feels 'tighter' in handling terms but the ride is definitely a bit harsher. 2012 TDV8 Vogue (L322) |
I had the same issue on both rears on mine. Fronts fine, but rears seized in the same way. Removed, cleaned up, copper greased (all I had to hand) and left them freely moving. I checked for play and roughness in the height sensor and all seems ok there at least. Has it made a difference? Yes and no. The ride is still more crash-y that I feel it should be… however some of the smaller bumps and imperfections seem better. The car felt worse at the rear than the fronts, whereas now they feel similar. For the effort involved I’d add this to the list of preventative maintenance tasks. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
I totally agree. My driving history has always been more sporty cars so I may not notice a harsh ride in the same way other may. Your tyre swap comment intrigues me. I’m running 22” wheels so am always going to have a harsher ride, but am using 45 profiles for an extra inch of tyre wall. It has helped, but the only way to know if my ride is just because of my tyres, or if I also have other issues, is by borrowing a set of normal tyres. And maybe a back to back test with another CVD L322. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 900 ![]() ![]() ![]() |
I don't think the tyre swap will make any difference, I sold my 22" rims to a VW Transporter chap, and went back to stock 20" alloy rims, and with the stock Pirelli Scorpion Zero 255/50/R20 tyres, all in an effort to get back to a stock car as much as I could - all this was in an effort to get back to a more receptive and compliant suspension, instead of feeling all the bumps and potholes in these pathetic UK roads we now drive on
I'm assuming that in a steady state of driving in a straight line the shock absorbers should go to their softest setting and only stiffen up to control roll in corners? Or have I / we got this wrong and they are firm most of the time to anticipate any driver steering input and make the handling feel tight and responsive and only soften when they sense undulating ground but simple things like cracks in the road or potholes just have to be driven over at a stiff setting as there is no way of reacting to these fast enough and no way of the car knowing if it's driven over just one crack or about to drive over 100's 2012 TDV8 Vogue (L322) |
