Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7829 |
Yes, as above, once you disconnect the connector you will get “Adaptive Dynamics Fault” on the dash, then you will really know what hard is 🤣 hang on to your fillings…. Think mine isn’t that hard, but not far off.
16th Sep 2022 1:42pm |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
For me it’s the “it’s not as hard” (stop sniggering at the back) part. If it was as hard as when disconnected them something is broken. Some days are worse than others for me with no real indication of what changed.
16th Sep 2022 2:05pm |
Indeed… that about sums up my thinking too. Mine is constant, doesn’t seem to do any adjustment, but something must be getting through or it would be solid.
16th Sep 2022 2:32pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2523 |
A PWM signal is used in order to control the extent of opening of the valve, achieved by changing the percentage of the time that voltage is applied. A PWM signal is at a constant voltage, 12V in this application and the current draw proportional to the duty cycle, the 12V "on" time. At 50% duty cycle the 12V pulse is for half the time which will cause the valve to be partly open (perhaps around 50%) whereas a 25% duty cycle the 12V pulse is for 25% of the time which will cause the valve to be less open (perhaps around 25%). The damper module may be programmed to use only a few different duty cycles, possibly in 25% increments. The 3rd component of a PWM signal is the frequency of the change from on to off, which is normally fixed for an application taking into account the use of the signal. |
16th Sep 2022 9:04pm |
Ah, ok, so for the valve to be half open, it wouldn’t get supplied with 6volt, as my simple mind may have initially thought, but 12v half the time… or close to….
16th Sep 2022 9:16pm |
2011 Range Rover Vogue SE 4.4 TDV8
16th Sep 2022 9:26pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
I've been doing a bit of reading-up on this...
16th Sep 2022 9:29pm |
I can’t see an adaptive dynamics wiring diagram in the diagrams in the workshop manual. I got it from the Wiki. May be that not all of it is there.
16th Sep 2022 10:04pm |
16th Sep 2022 10:06pm |
I suspect that the last 3 possible positions were for another vehicle which should have been replaced by the 1st 3 when that part of the documentation was copied from elsewhere.
17th Sep 2022 12:50am |
Thanks - it was more the pin-out of the module I was after, we can get round it, it'll just take a bit longer |
17th Sep 2022 6:19am |
https://www.fullfatrr.com/gallery/albums/userpics/15719/CVD~0.pdf |
17th Sep 2022 7:44am |
Excellent - thank you! |
17th Sep 2022 7:57am |
So, had a cracking few hours with Haylands and Phoenix. We came to the conclusion that the shocks were ok, but the first thing we saw was that the front right accelerometer was giving a changing reading when the car was stationary, which obviously isn’t right. Then we went for a drive and saw that the front left height sensor was reading low and a bit intermittent/behind the 3 others. So the ECU would be thinking the corner was leaning all the time, and try to compensate.
17th Sep 2022 7:26pm |
