![]() | Home > Technical (L322) > Forced DPF Regeneration using Gap iid. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Great news, but don’t force it too often or you will risk getting oil dilution problems and need to be doing extra oil changes..
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2664 ![]() ![]() |
It’s been saying needing a service for a wee while ..... better get it booked in next week not too long since a major last year , not done huge miles , but clearly needing an oil change . |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1264 ![]() ![]() ![]() |
Just changed my oil because it said service needed. My IID tool said oil dilution was 3. So is the mileage involved as well? |
Thanks Mike. I'll count 3 as being good then, probably. |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
I'm just about to try this forced regen as I've had my first ever yellow warning (which has actually gone off again now - I actually think the garage did something as it came on when it was being delivered home after a service).
Sorry, but I can’t give you a 100% answer because I have had different experiences , but what I usually do is watch as the soot gramma fall to single figures then stop at the next convenient place, lay-by etc and stop it by pressing the Quit word and removing the iid.
Cheers. I'm not sure when I'll get a chance to do it but will do what you suggest when I do. 2010 4.4 TDV8 Vogue SE |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 ![]() ![]() |
Ok, all good info.
Just an observation that I will add……..
Absolutely agree. On other cars where I've had this facility with a diagnostic device it's come with big warnings. Should only be used in emergencies and if a long >50mph run doesn't clear a yellow fault you have other issues that need fixing ASAP 2012 TDV8 Vogue (L322) |
Completely agree - the Successful Regen field does not populate consistently after regens - natural or forced and under the same conditions it will sometimes tick up sometimes not.
I haven’t needed to use the iid forced regen facility for a while, but today I decided to give it a good clean out .
gotters Member Since: 15 Aug 2015 Location: London Posts: 41 ![]() ![]() ![]() |
I love this forum for educating me on the DPF in my car and helping me avoid the dreaded amber or red warnings.
