Home > Technical (L322) > Forced DPF Regeneration using Gap iid.
Page 2 of 6 <123456>
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Hey Mike,
Been good mate. Due to COVID the car doesn't get any long runs at all , especially now that i'm no longer on the road for house calls etc. Every wednesday night after i drop one of the kids off at guides, I'll go for a 25 mile forced regen run so it doesn't get near the 1st trigger. This has been a fantastic addition to the toolbox, and again has saves quite a sum of money in the long run.
Cheers
steve
Post #623893 16th Feb 2022 3:27pm
Baltic Blue
Great news, but don’t force it too often or you will risk getting oil dilution problems and need to be doing extra oil changes..
Mike Thumbs Up G reg 2.5VM Vogue Portofino red 1991- 1999
Post #623897 16th Feb 2022 3:45pm
Mr Tee
It’s been saying needing a service for a wee while ..... better get it booked in next week not too long since a major last year , not done huge miles , but clearly needing an oil change .
Post #623933 16th Feb 2022 9:01pm
kevinp
Just changed my oil because it said service needed. My IID tool said oil dilution was 3. So is the mileage involved as well?
Post #623937 16th Feb 2022 9:25pm
Baltic Blue
The WM gives this explanation , all very complicated, but seems to involve, time since last service, amount of fuel used, mileage, ??
Post #623939 16th Feb 2022 9:47pm
kevinp
Thanks Mike. I'll count 3 as being good then, probably. Confused
Post #623954 16th Feb 2022 11:42pm
kooky_guy
I'm just about to try this forced regen as I've had my first ever yellow warning (which has actually gone off again now - I actually think the garage did something as it came on when it was being delivered home after a service).
Does the forced regen process complete itself, or do you have to quit when you think it's done enough? 2010 4.4 TDV8 Vogue SE
Post #627310 30th Mar 2022 11:13am
Baltic Blue
Sorry, but I can’t give you a 100% answer because I have had different experiences , but what I usually do is watch as the soot gramma fall to single figures then stop at the next convenient place, lay-by etc and stop it by pressing the Quit word and removing the iid.
I usually then complete my journey and check the final figure in live values.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #627318 30th Mar 2022 11:36am
kooky_guy
Cheers. I'm not sure when I'll get a chance to do it but will do what you suggest when I do. 2010 4.4 TDV8 Vogue SE
Post #627322 30th Mar 2022 11:48am
Range Rover L322
Ok, all good info.
I recommend only doing a forced regen as an absolute last resort. It blows through the safety nets and can be quite brutal to the matrix on the DPF and/or the cat. Relying on it regularly or as a standard operating procedure is a bad idea in my opinion. Personally I would only run it if stuck on a red or to get home. On a yellow try and get the car to clear itself naturally.
If you're getting warning lights it generally suggests another issue like induction system if you're not mis-purposing the car for something like city driving.
The oil dilution figure on the IIDTool is inferred and not measured. It is calculated by the number of regens since the last service. It is not a very reliable indicator.
. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #627405 30th Mar 2022 11:32pm
Baltic Blue
Just an observation that I will add……..
The number of successful Regeneration count in live values does not change after a forced regen has been completed, so this may well affect the “oil dilution “ calculations, but the overall contamination must be affected.
Post #627423 31st Mar 2022 8:48am
JayGee
Range Rover L322 wrote:
Ok, all good info.
Absolutely agree. On other cars where I've had this facility with a diagnostic device it's come with big warnings. Should only be used in emergencies and if a long >50mph run doesn't clear a yellow fault you have other issues that need fixing ASAP 2012 TDV8 Vogue (L322)
Post #627427 31st Mar 2022 8:55am
Range Rover L322
Completely agree - the Successful Regen field does not populate consistently after regens - natural or forced and under the same conditions it will sometimes tick up sometimes not.
This is definitely a controbutory factor to the well known unreliability of the Oil Dilution...
FYI Demanded Regens is spot on and is the best way of seeing if the car is requesting a regen. On mine it kicks in like clockwork at 19.7grams of soot. Also I have replaced every sensor including the pressure differential which calculates the DPF soot fill and it still kicks in at 19.7grams. 2012 L322 4.4 TDV8 AB low mileage - a peach
Post #627502 31st Mar 2022 11:24pm
Baltic Blue
I haven’t needed to use the iid forced regen facility for a while, but today I decided to give it a good clean out .
Here are the screenshots.
I know from past experience that the display doesn’t show readings below 1g correctly, and that 6g is actually 0.6g as confirmed by the live value reading of 0.558g at completion.
Post #638417 1st Aug 2022 1:43pm
gotters
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Santorini Black
I love this forum for educating me on the DPF in my car and helping me avoid the dreaded amber or red warnings.
Spent a good few hours earlier in the year trawling thru all the threads and getting the facts straight in my head, it's a goldmine of cold hard data and user experience/knowledge.
I rarely get long runs nowadays so keep an eye on this using my Gap tool and have successfully called in a few forced regens
Any word if they're going to include it in the proper build and not in beta only, wonder what is preventing them from releasing it fully into the live code ?
Post #638420 1st Aug 2022 2:18pm
