Home > Technical (L322) > 4.4 TDV8 no start no crank
Page 12 of 12 <123 ... 101112
JayGee
looking forwards to following the rebuild. 2012 TDV8 Vogue (L322)
Post #637315 19th Jul 2022 1:17pm
johnboyairey
PeterRRVogue wrote:
Engine bits delivery Smile
Whilst you have the opportunity, the near side exhaust manifold, has a gas temp sensor with wire connection. This often fails, and gives code p0040d. It’s a pain to get out, and often snaps off. It has a sort of brake line nipple connection. You might want to try and ease the nut with a lot of penetrating fluid. Just in case it needs changing, as it’s impossible to deal with if broken off… without getting manifold off, which needs engine out. Mine broke, so I had to make a resistor to simulate the warm engine temp. (helps DPF regents)
Post #637319 19th Jul 2022 2:36pm
PeterRRVogue
Thanks for the tip Johnboyairey! Mine was already partially fixed. I mean, the old one was still in the manifold unplugged and a new one was connected to the harness and just tied to the side of the manifold Laughing So will get it right before putting things back Thumbs Up
Post #637343 19th Jul 2022 7:55pm
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Good luck with this job, and I must say I'm looking forward to seeing any videos that you do Thumbs Up
Post #637406 20th Jul 2022 11:28am
JavaBlack
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
Hi Peter,
Any updates?
Post #649481 29th Nov 2022 8:20pm
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
Cliff hanger!!!
Any updates?
Post #665017 25th May 2023 12:41pm
