Home > Maintenance & Mods (L405) > First oil change - please help a fool
Page 3 of 3 <123
DrRob
Yes. Twist and pull up. Don't drop it! Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #633441 1st Jun 2022 10:12am
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Thank you, @DrRob What do I put here then?
Post #633442 1st Jun 2022 10:15am
GAC23
Oil arrived yesterday Smile
So today's the day ...
Doing a final read of the "instructions", how do you take off the engine cover - looked in the Wiki but couldn't spot anything? What do I put here then?
Post #633846 7th Jun 2022 9:08am
Baltic Blue
Park the car on a level surface, open the bonnet and work from the front.
One hand on each side of the engine cover and lift it with a good pull upwards,
Best wishes
Post #633850 7th Jun 2022 9:36am
GAC23
Thanks yet again, Mike.
I'd had a look at it and assumed there were hidden bolts or screws. What do I put here then?
Post #633852 7th Jun 2022 9:42am
supershuttle
Everything has arrived just have to nip over to ECP for a filter, would have done it this morning but looks like I have a puncture Big Cry Geoff
Post #633880 7th Jun 2022 11:48am
Gremlin500
…………… “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #633905 7th Jun 2022 4:05pm
Gremlin500
…………. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #633907 7th Jun 2022 4:06pm
GAC23
Thanks for the tip and link @Gremlin500 What do I put here then?
Post #633908 7th Jun 2022 4:09pm
GAC23
So ...
All set to do the oil and filter last night.
Suddenly thought to check the "Oil Dilution" on the GAP IID.
It's showing as 7.4 - estimated or however it words it. Engine wasn't running but assume I can trust the figure.
Which means the car is probably due a proper service.
Or am I wrong? What do I put here then?
Post #633999 8th Jun 2022 9:34am
Baltic Blue
It will reset to zero when you use your iid to reset the service indicator.
Yes you are definitely due an oil change. Get it done ASAP.
Post #634009 8th Jun 2022 11:12am
GAC23
Thanks, Mike.
I thought they'd altered the dilution percentage to 14 before it triggered the oil change needed. What do I put here then?
Post #634012 8th Jun 2022 11:18am
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Could someone please give me a clue on how to check the Oil dilution wiht an IID Tool?
Thanks
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #634027 8th Jun 2022 12:22pm
Baltic Blue
It’s in Live values.
Select PCM Engine v8, then
Look down list of available readings and select.
Oil quality fuel dilution factor.
Zero reading after last weeks oil change reset.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #634034 8th Jun 2022 1:01pm
IGP
@Baltic Blue Thanks you very much.
Post #634035 8th Jun 2022 1:09pm
Page 3 of 3 <123
