![]() | Home > Maintenance & Mods (L405) > First oil change - please help a fool |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Yes. Twist and pull up. Don't drop it! |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Thank you, @DrRob What do I put here then? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
Park the car on a level surface, open the bonnet and work from the front.
Thanks yet again, Mike.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3892 ![]() ![]() ![]() |
Everything has arrived just have to nip over to ECP for a filter, would have done it this morning but looks like I have a puncture |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1667 ![]() ![]() ![]() |
…………… “If it ain’t broke, don’t fix it” -where’s the fun in that? |
…………. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
Thanks for the tip and link @Gremlin500 What do I put here then? |
So ...
It will reset to zero when you use your iid to reset the service indicator.
Thanks, Mike.
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 298 ![]() ![]() ![]() |
Could someone please give me a clue on how to check the Oil dilution wiht an IID Tool?
It’s in Live values.
Zero reading after last weeks oil change reset. Mike G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
@Baltic Blue Thanks you very much.
