Home > Technical (L322) > 4.4 TDV8 no start no crank |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 741 |
Unfortunately I think this could be the best advice that you might get about this car, I suspect that the chances of making a viable car from this to be very low. There are so many red flags, that engine sounds very ill and even if you did get it running I can't imagine that the turbos are going to be any use looking at the state of the oil filter. The neglect needed to get the oil and filter into that state is simply staggering so it's doubtfull that any other maintenance has ever been done. This one looks like a classic money pit. Sorry to sound so negative about it but it is so easy to keep going once you've started spending it can be difficult to give up |
21st May 2022 5:06pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1219 |
quote' some of the above comments about wasting time etc... are not helping'
21st May 2022 6:25pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
KevinP, you need to know what problem you have, before you go ahead and take the engine out! we can all say things, and every bit of advice is good advice, ir in case something has been overlooked. the thread starter bought the car, so he's 'in it' now, and is looking for advice, not guesses on cost. we are all guessing the problem... with the few facts and videos available. he's further down the road than when he got it, but im sure a compression test is what he needs now. thats not going to cost a fortune. |
21st May 2022 7:09pm |
PeterRRVogue Member Since: 22 Jan 2022 Location: Brackley Posts: 72 |
Hi guys, sorry for not posting here for a while. Been busy with work and a bunch of house projects, while also thinking and researching my options re the RR. So I wanted to let you know that I have come to a conclusion (which I kind of knew right from the beginning, just hoped to be wrong) that this is going to be an engine-out job. I appreciate all the suggestions and comments that all of you guys offered and I took them all on board. The more I was thinking about it, the clearer it was becoming that I'm either gonna have to cut my losses and sell the car or I'm gonna have to spend a lot of money/time to get it fixed. Me being me, I decided to go down the engine-out path and recondition it myself (excl. the machining work of course) It might turn out to be a big mistake, but the challenge kind of excites me and at least I'm gonna learn a lot in the process. Also, I thought that since there seems to be no comprehensive write up or video content (that I could find at least) on how to do a complete rebuild of the 4.4 TDv8, I might use this as an opportunity to pay back to the car community for all the knowledge I have benefited from over the years (on my other cars and bikes) and hopefully make a content that someone might find helpful in the future. I'm going to start with taking the engine out this upcoming weekend so I will keep you posted on my journey. I will try to video record the whole thing in detail so I can share it with you guys and provide some useful or comedic (depending on the extent of my failures) value in the process. Wish me luck |
6th Jun 2022 9:39am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7812 |
Definitely getting your sleeves rolled up then…. Hopefully you will find something a bit more conclusive when you look a bit deeper and it’s not too bad to resolve.
6th Jun 2022 9:52am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1345 |
Check availability of parts, iirc might be more chance of winning the euro millions than getting a hold of some items.
6th Jun 2022 10:13am |
I already have and at least for the obvious items, it didn't seem to be an issue, for this engine at least. But I wouldn't be surprised if I will stumble across a supply issue at some point. Obviously, until I take the engine apart and find out what needs fixing, I won't know what needs replacing (apart from the obvious items eg. gaskets, stretch bolts etc.). One thing I haven't got to the bottom of yet is finding (ideally a UK-based company) that can check/test and possibly remanufacture my injectors. Any suggestions would be welcomed! |
6th Jun 2022 10:31am |
Would have thought most diesel injection service places would be able to handle that tbh, or are they specifically made to be as awkward as , says me, waiting on delivery of a rear flexi brake pipe because there's not one available in the whole of Portugal |
6th Jun 2022 10:54am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3108 |
This website could be your best friend
6th Jun 2022 11:19am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
Thanks David - never knew that existed..... 2012 TDV8 Vogue (L322) |
6th Jun 2022 11:28am |
this sounds a great idea. I just happened to get this YouTube suggested, on my feed... I don't know what they are talking about. (German?) but the pictures of the engine... from about 1/4 the way in, and also 3/4 way through.. are a bit sobering. |
7th Jun 2022 8:29pm |
So I've made a start and removed the whole front end with the radiator pack. Ordered timing chain and trigger ring installation tool, heavy duty engine stand and borrowed my mates engine hoist. I'm still looking to find a set of engine lifting brackets as I'd like to avoid having to fabricate these myself if I can (any tips would be welcome). I'm aiming to have the engine out this weekend (with a bit of luck). I've been recording the whole thing so I will post a video on the comprehensive engine removal once done.
15th Jun 2022 2:45pm |
Thanks Johnboyairey, the oil in those two engines from the video looked very similar to the state of mine so I'm hoping that my engine block and (mainly) crank will be still salvageable. It's possible (even likely) that they will be worn beyond maximum oversize. Eitherway, I guess I will find out soon! PS: I don't speak german either but you can enable auto translate subtitles in that YouTube video which is better than guessing Ta |
15th Jun 2022 2:54pm |
How are you getting on with your project, Peter?
13th Jul 2022 10:09am |
