Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 106 |
You have a good point there |
18th May 2022 6:11pm |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
This is interesting. If the working theory is correct in that the fronts are ‘fooling’ the rears to stiffen up, then yes it makes sense that the rears would be soft when reversing!?!? I will give that a go at some point soon and will report back. Also, yes the placebo affect could be a big factor! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
18th May 2022 6:44pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
I can’t wait for Sam to fit some new front shocks and hopefully solve the mystery Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
18th May 2022 6:46pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7812 |
And this is what I don’t understand, or my logic is wrong….
18th May 2022 7:05pm |
LandyManSam Member Since: 10 Jul 2019 Location: Wild West Ireland Posts: 51 |
Where did you get the LR Engineering paper? And what happened to it? That'd likely be exactly what we need right now! Sam's Motor & Machine YouTube Channel: https://www.youtube.com/channel/UCgNSRjY0I9FCzsi9ku3ccbw
18th May 2022 8:53pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 677 |
Sadly I don't feel I have an answer to the question/ theory of why a bad shock causes the system to flat out fail at doing its job but I am now fairly certain the answer lies in a faulty shock as opposed to a faulty sensor based upon mine and coopss experiences successfully resolving this issue.
18th May 2022 8:58pm |
I’ve also replaced a knackered rear shock and seen no change. Put 2 new Bilstein units on.
18th May 2022 9:27pm |
18th May 2022 10:04pm |
That’s great information, so I think my fronts are firmer than they should be and I guess the valve is not opening when demanded, so when they hit a bump the accelerometer senses a force greater than what it would normally be, this then stiffens the rear to prevent bounce or roll. This will then continue and cause the harsh ride.
18th May 2022 10:23pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
if you can get hold of a Icarsoft V2 you can monitor in Realtime the voltage and NM value of each damper.
19th May 2022 7:20am |
Just to update
19th May 2022 7:23am |
There are a few icarsoft V2 on the bay of e, but I’m not sure if they all cover the same modules, some just say ABS, SRS etc… don’t want to look at one and then it not do it.
19th May 2022 7:53am |
I’m curious about that too… there are two wires to each strut so how does it supply both the volts/amps needed and get the NM value back?
19th May 2022 8:08am |
It’s going to be a little while longer for me. My less than a year old Delphi control arms need replacing so will be putting in genuine like I should have done in the first place. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
19th May 2022 8:11am |
