Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322!
Page 7 of 30 <123 ... 678 ... 282930>
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
MarianaWestminster wrote:
I am now of the feeling we might all have a bad front shock throwing out the system. .
I have in the past dismissed the fronts because of how the car feels when going over speed bumps. I would expect that the fronts would be harsh but the rears would be softer. I don’t feel that in mine..l
That being said, you and coopss may be right and we will not know unless we swap the fronts. As mentioned before it is on the cards for me, but way, way down the list. Swapping of the accelerometers is more likely, but I’ve not looked how you do that to the ones not in the boot. Are they just sat behind the wheel liners? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #631434 12th May 2022 6:59pm
Ffrr-lover
MartinD wrote:
Are the fronts more expensive than the rears?
About £300 rears and £600 fronts I believe. Sad Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #631435 12th May 2022 7:00pm
mjdronfield
About £350 plus VAT as opposed to £200 plus VAT…..
https://www.island-4x4.co.uk/spring-strut-...27714.html
https://www.island-4x4.co.uk/rear-shock-ab...23661.html
I got Bilstein rears, but the fronts seem to be rare if you want the same brand.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #631436 12th May 2022 7:02pm
Ffrr-lover
They are better prices than from Duckworths!
Same parts too Thumbs Up Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #631443 12th May 2022 8:14pm
mjdronfield
I did a bit of shopping around when I needed my rears changing.
Looks like they are also pretty competitive for the fronts too.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #631445 12th May 2022 8:54pm
mjdronfield
I’m guessing the other accelerometers are either behind the wheel arch liners or inside, behind the kick panel where your feet are. Was gonna ask if anyone knew for sure…..
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #631446 12th May 2022 8:58pm
MarianaWestminster
Okay my friends I have an update for you!
First of all testing the front shock theory.
After a harsh ride down to Mynydd Mostyn dairy in Wales I decided to bounce test the shocks.
This was done with the car switched off although I did also test with it running and noted not much difference if any so I concluded the shocks must not be energised until driving.
I went round the car and bounced each corner and found the drivers side to be stiffer compared with the passenger side.
Enlisting the help of a friend the two of us went to town bouncing the drivers side by pressing down on the slam panel with the bonnet open.
Driving back home we found that the ride although not 'perfect' had infact improved!
I decided to bite the bullet and headed down to Maltings off road for a new shock manufactured by BWI the original suppliers to Land Rover.
When fitting said shock I found the drivers side to be an original unit from 2011. The passenger side is a Bilstein with a date code of 2018.
Shock fitted, low and behold we have suspension again!
Whilst definitely not as soft as a pre CVD L322 it certainly is a whole lot improved and I would describe the ride quality as 'firm but fair'
I have done around 200 miles with no loss of ride quality but will continue to monitor and update if anything should change.
Hope this helps anybody who is struggling with this issue.
Post #631786 15th May 2022 10:11pm
mjdronfield
Oooo that’s excellent news, and ties in with what a few others have found.
I think the shocks go softer the more they are energised, so should be pretty firm with the engine off.
I’ve not seen any Bilstein fronts for sale, so looks like BWI is the way to go front wise.
I think you can get away with doing one if their age isn’t too fat apart, but they include the air bag too I think, so hopefully you won’t notice any change side to side.
See how you go then.
Never gonna be too magic carpet ride as on 20 inch wheels with 50 profile tyres.
What did you pay for the strut?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #631790 15th May 2022 11:35pm
mjdronfield
I wonder if just putting a front wheel up a bank might have the same effect? Like making the shock compress…..
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #631791 15th May 2022 11:38pm
Ffrr-lover
That is good news MarianaWestminster!
I still don’t see a link as to why the fronts affect the rears like they do, but have added new fronts to my shopping list. Frustratingly my Delphi front control areas which are less than a year old need replacing (lots of play even from my hand moving them) so need to pay another £700 for those. Yet more delays for me.
I see Sam has a new video online about this too. He mentions he is also soon going to replace his front struts. Let’s see how that works out for him! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #631796 16th May 2022 7:08am
Ffrr-lover
Would lowering the car also have the same effect? Maybe raising fully then lowering? Or even possibly lowering to the bump stops for even more compression? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #631797 16th May 2022 7:13am
mjdronfield
Yeah, I thought that…. as the shock would have to compress to let the car down, along with the air bag. That would be all 4 corners though, and, well, you don’t want to cause an issue you didn’t have before Rolling with laughter
Seriously though, might help. Worth a try to prove something.
I can’t see why it would affect the rears either….. but my rears were changed for new ones, and still the same….
I did wonder if you can measure voltage on the wires to the front struts, if that’s even possible, and see if the control unit is even trying to soften them. Most will have had the wire fix by now and will have a join in the wire to get a read point from. Just thinking aloud….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #631805 16th May 2022 8:37am
JayGee
Maybe bouncing the car made the AD ECU think it was traversing rough ground and it softened off the damping. No one really knows how this system actually works. 2012 TDV8 Vogue (L322)
Post #631806 16th May 2022 8:41am
MarianaWestminster
Good ideas regards lowing the suspension to compress the shocks 👍
JayGee I did also think that might be a possibility.
I should have also performed the test with the ADCM unplugged however we were in a rush to leave at that point to reach our next stop on the journey.
I forgot to add that once the old shock was off the car I found it very difficult to compress and it came back up very slowly!
Post #631816 16th May 2022 10:05am
JayGee
What tyres and size are you running BTW. I commented on Sam's latest Youtube video that his oversized all terrain tyres will be stiffer than normal road tyres which will make for a harsher ride just as low profile road tyres will. 2012 TDV8 Vogue (L322)
Post #631818 16th May 2022 10:11am
