![]() | Home > My Range Rover > My 2005 4.2 Supercharged - here we go.... |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 395 ![]() ![]() ![]() |
So, after selling my 2010 3.6 TDv8 in February I started looking for a 4.4 TDv8 Westminster .... and like you do, ended up buying this 2005 (2006) model 4.2 Supercharged on Good Friday
2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics Last edited by Superspoons on 17th May 2022 2:14pm. Edited 1 time in total |
Thanks David.
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
Very nice |
cb07 Member Since: 09 Feb 2022 Location: Hertfordshire Posts: 48 ![]() ![]() ![]() |
Congratulations it looks superb!
Mr Glover - Yep, a little but as expected and very fixable.
Draper Pump -
Slacken the Filler first otherwise you'll be stuffed if you drain the diff first and can't get any back in as it won't budge. Filler -
14mm Hex head to undo -
Drain Plug -
Again, 14mm HEX head to undo - This is what came out - Just about 0.70 litres of dark smelly well used Diff Oil -
No metals in it although it did have a 'silvery tinge' if that makes sense and boy did it stink of cats wee ![]() Drain Plug -
I think the Magnet did it's job...sludge and filings...
Clean it up and screw it back in Measured 0.75litres of Diff Oil out..
...and transferred to the Draper Pump - handy little thing and works well. Draper was showing just over .80 litres in its bottle but I can live with that and didn't use about 0.05 litres, so worked out fine in the end.This isn't a F1 car after all -
Screwed the Filler plug in after cleaning it up. Its a tapered thread - don't over tighten it as the case of the Diff is surprisingly thin. Transfer Box & Rear Diff guide to follow... Gavin 2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics Last edited by Superspoons on 6th May 2022 11:51am. Edited 1 time in total |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3192 ![]() ![]() ![]() |
It’s very common for the oil that comes out of the rear diff to be horrible stuff.
You weren't joking David ![]()
..Chocolate Mouse springs to mind ![]() Rear Diff Oil Change - The remains of the Filler Plug... no way could I get this out. I tried an over size star drive, heat and even to tried to cut a little slot for a screwdriver but my Dremel disc was too big. This might explain the colour/condition of what came out... had it ever been changed in 80,000 miles ...?
So the only way to fill this up would be via the breather hose. I slipped it off -
Cant get a picture of the other end but its up there .. and undid the drain plug - again another 14mm Hex Head.
Some filings on the plug but surprisingly not to bad...Just over a litre came out and I left it to drain for a good 30 minutes whilst tea and biscuits were taken -
Cleaned up -
Screwed back in and then measured out the first of many Syringe amounts to make up 1.2 Litres. Painful as the hose attached to the syringe has a small bore and requires a lot of pressure to transfer to the diff via the Breather fitment on the diff.
Took around 30 minutes to get it all in. Fitted the breather hose back onto the Diff and job done. Transfer Case next....which should be easier ....there, I've said it. Gavin 2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics Last edited by Superspoons on 17th May 2022 1:28pm. Edited 2 times in total |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 504 ![]() ![]() ![]() |
Nice looking Supercharged Superspoons, they do scrub up well.
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
when i do mine i cover the hole of the filler plug and drain plugs with a very thick water pump grease all over the plug you have to use a small scraper blade to put it on so it is sealed . it stays on very well and then just wipe off the next time no rust like new new vehicle purchase
Hi Peter - Thanks. No they were on there when I bought it. I'm in two minds what to do. They do protect the doors from damage, but the adhesive is failing in a couple of places. The worry is they take off some of the lacquer or worse if I removed them. Im up Knebworth way. Gavin 2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics Last edited by Superspoons on 9th May 2022 9:18am. Edited 1 time in total |
Yes, just needed to get it out the first place. I've put an amount of mastic in filler plug heads before and that works well too ![]() 2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics |
Hi Peter - Thanks. No they were on there when I bought it. I'm in two minds what to do. They do protect the doors from damage, but the adhesive is failing in a couple of places. The worry is they take off some of the lacquer or worse if I removed them. Im up Knebworth way.[/quote]
Transfer box oil change -
Both the filler and drain were T50.
Undid the filler after cleaning around the area -
Its up here. Mine was in poor shape -
I'd ordered a new one anyway (old one outside the packet, new inside ![]()
Undid the drain plug which was in good condition - ..and drained the oil -
Fitted the Drain plug after cleaning it up and replaced the cooper washer on it with a new one. Used my Draper pump bottle to fill it up with 1 litre first and pumped it in. The remaining 0.5 litre followed -
Just shy of 1.5 litres went in - it started to dribble out of the Filler plug so put the new one in and nipped it up. Job done. Gavin 2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics Last edited by Superspoons on 17th May 2022 1:28pm. Edited 1 time in total |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2276 ![]() ![]() ![]() |
Job well worth doing I do all of mine every 30k so about 18months and all working superb they do if you look after them |
