Home > In Car Electronics (L322) > NavTool - Carplay, HDMI mirroring, video in etc. 2008 L322
Page 11 of 12 <123 ... 101112>
mickb
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Thanks guys,
Will have a look and see if its connections.
Weegie, the factory fitted reverse camera is working intermittently.
Just to add to it all the key fob has now stopped working AHHHH
I am using a USB Cable although have both Usb and HDMI run from the unit the USB Cable is this one
https://www.amazon.co.uk/gp/product/B08GP6...&psc=1
https://www.amazon.co.uk/gp/product/B088PW...&psc=1
Will try HDMI thanks really appreciate help ass I am not very techy
Post #608362 5th Oct 2021 6:11pm
Weegie
The USB should be fine. Re the problem with the reverse camera, have you got surround cameras? Unlikely I would have thought with your model year.
Ask the people who fitted it if they have programmed it for cameras when they set it up as that might cause problems John
GAP iiD BT-Sold
Post #608367 5th Oct 2021 6:43pm
Dommo
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Took advantage of the version 5 offers Navtool have been doing (Not wireless), fed a USB cable through to the centre storage unit and the 3.5mm audio into the rear aux ports. All working a treat - I think the plug and play loom makes for a much nicer install experience than what was required at the start of this thread. Not sure if I'd have been bothered to hack about like that.
It's been faultless so far, quite tempted to get a camera to use for lining up the towing hitch... I suspect the ability to add cameras is going to be just as useful as the phone bits!
Post #630587 3rd May 2022 11:52pm
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
ctjfb wrote:
I had it shipped to the UK and fitted it myself - not a difficult job if you can solder a few wires together. I'm sure any auto-electrician would do it for a reasonable price .. It fits in the boot next to the SatNav so no dashboard dismantling required.
Chris
I think this is the critical bit! I’ve seen one referred to elsewhere where he has to dismantle the head unit itself to put a new circuit board in!
May splash out on this. Thanks for a great write up. Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #640900 25th Aug 2022 8:55pm
tymh
Just ordered mine and there’s a free wireless CarPlay extra with it. Tym
Post #640911 25th Aug 2022 9:53pm
Weegie
I have the wireless version in my 2008 FF. It is completely plug and play. The instructions may not come with it but if you contact them they will send you a copy. I think they are being over protective of their product. They want to confirm you have a unit from them?
If you have a problem I have the instructions somewhere.
IMHO it is excellent. I don't even need to take the phone out of my pocket.
There have been some upgrades since the version 4.0. For example, you can set the screen for right or left hand position. Helps with SWMBO as she can have the screen controls on her side to fullfil her "controller" function. Whistle John
GAP iiD BT-Sold
Post #640972 26th Aug 2022 3:08pm
tymh
Re: NavTool - Carplay, HDMI mirroring, video in etc. 2008 L3
Unnecessary quote removed
Just realised that this may be why my Siri isn't working. I didn't get a microphone with my kit. "Hey Siri" wakes it up, and it waits for me to speak, but I think that's the phone that's picking it up. If I try to send txt using Siri as I used to in the Merc, nothing happens - it doesn't pick up my voice. Tym
Post #650544 12th Dec 2022 1:21pm
Weegie
From your previous post, you have the wireless Version 6 0. There is no mike supplied with it as it uses the original car mike John
GAP iiD BT-Sold
Post #650545 12th Dec 2022 1:30pm
tymh
That would explain it. Tym
Post #650546 12th Dec 2022 1:32pm
DanPoole
United Kingdom 2012 Range Rover Autobiography TDV8 Orkney Grey
Hi Tym,
I also have the wireless version 6 and no mic, however my Siri works fine. I haven’t used it for texts, but have for requesting music through Spotify. The phone mic picks it up and it is then relayed to the Navtool through CarPlay. 2012 4.4 TDV8 Autobiography
2005 4.2 V8 SC
2003 4.4 V8
Post #650639 13th Dec 2022 11:57am
Broombrooma
United Kingdom 2008 Range Rover Vogue SE 4.2 SC V8 Java Black
Whats the sound quality like when you play back music through apple car play wireless connection?
Is it noticeably different?
Post #650697 14th Dec 2022 4:10am
Weegie
The audio is still wired through the AUX. The wireless aspect is for the connection of the phone to the car. John
GAP iiD BT-Sold
Post #650702 14th Dec 2022 8:44am
th3chainrule
United States
How is the sound quality on the Navtool in comparison to the CD player or Bluetooth?
Post #665506 31st May 2023 12:02am
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
So, i bite the bullet and ordered a unit. But it seems i get a faulty one. I installed everything like manual (the version with adapter harness) but the interface will not show up, i hear the chirp but my screen says no navigation fitted. Dis anybody experienced this failure? Thanks
Post #665826 3rd Jun 2023 7:12pm
clemenz
Navtool Support was helpful, i needed to connect an additional cable to the harness. now everything is working Smile
Post #666162 8th Jun 2023 11:37am
