Home > In Car Electronics (L322) > NavTool - Carplay, HDMI mirroring, video in etc. 2008 L322
Page 10 of 12 <123 ... 9 101112>
Weegie
Haven't tried it. Rather expensive. It would mean pairing the phone to it and for me I prefer my phone pairing to the car's system. Might suit others though. John
GAP iiD BT-Sold
Post #571497 1st Nov 2020 6:26pm
andyt109
Just read the entire thread, great stuff everyone! Tempted to buy one, a couple of questions first:
Does the CD changer still work?
Does it work with RSE? (I've seen a couple of people ask this in the thread but not seen an answer)
What happens if I put it in reverse? Does it still show the reversing camera? If so, on stock system or navtool? (the wife wants the car to not become 'annoying' when normal functions just don't work because of an 'upgrade' lol)
There are 2 models listed on the website, one for $300 odd and the other for $500 odd. Which have people on here been buying and what is the difference? I am an android user.
I have a 55 plate 4.2 SC with RSE.
Cheers
Post #580921 24th Jan 2021 10:18am
PianoJD
United Kingdom 2006 Range Rover Vogue 4.2 SC V8 Causeway Grey
Yes, the CD changer still works.
RSE: haven’t tried it, but in theory on the RSE you’d just select Aux as your source and would hear that audio. Not sure you could send video to the headrests but maybe someone else can advise on that one.
Reverse cam works as normal; overrides navtool on the screen then goes back to normal once driving forwards again.
I paid for one that was on offer at the time but stated a ‘normal’ price of $549.99. Can’t remember what the difference is I’m afraid.
Post #580932 24th Jan 2021 12:28pm
ultron
Germany 2008 Range Rover Vogue TDV8 Java Black
Hi,
ground loop- Problem....
with two isolators I did not succeed...
3-way shielded cinch cable was the solution ....after one year it is quit...yeah...
just for your information...
sebastian
Post #594686 19th May 2021 10:03am
Weegie
The system works in parallel with the original system in the car which remains fully functioning.
Effectively you toggle between the two systems using the NAV button on the headunit. The only other thing you have to do is, as said, select Aux on the audio screen. If you toggle back to the original remember to switch back to CD.
When you press and hold the NAV button the screens shows the two options of ON Road Navigation and OFF Road Navigation. Continue to hold the NAV button and the Navtool screen pops up.
To install you splice into the leads to the connectors on the Navigation DVD unit and I obtained some of the plugs for the unit from a member on here who was breaking the car. I got him to keep the longest leads to the plugs he could as it made soldering/splicing into them much easier. Otherwise you are working with a short tail on the plugs which is more awkward you are connecting into the loom which runs back into the car with not much spare.
Obviously not impossible but if you can source some second hand navigation DVD plugs it is worth while. (Hope that is understandable)
I (and MOH!!) am very pleased with the system as it brings it more up to date. John
GAP iiD BT-Sold
Post #594697 19th May 2021 11:34am
mickb
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Hi ctjfb can you please inform me what other cables you had to purchase and what one s you purchased. Also do i need to install the microphone in order for it to all work properly.
If I want the mirroring to work do i need an HDMI cable?
Post #607607 28th Sep 2021 5:00pm
Weegie
Just to answer your microphone question, I haven't fitted it. Its primary use would be for voice controlling your phone and, as MoH is the controller of everything when in the car I didn't bother Very Happy .
It transforms the experience. I have waze, Spotify on screen. If you get a text it will read it out to you.
The original in car hands free works fine in parallel for phone calls. You can have an HDMI cable or use a dongle connected directly. Again it's something I haven't troubled to do. If you get an HDMI cable it just needs to be long enough to reach your phone and you will need an adapter for your phone. John
GAP iiD BT-Sold
Post #607612 28th Sep 2021 5:50pm
mickb
Hi Weegie, thanks for the reply.
I am not very techy got someone else installing it for me.
If you don't use the hdmi cable how do you mirror the phone on the screen.
Thanks
Post #607768 30th Sep 2021 10:02am
Weegie
There is also an USB outlet which mirrors the phone. It leaves the HDMI clear for Firesticks and the like.
I haven't bothered with the HDMI. The USB works perfectly. Mine in use:
 John
GAP iiD BT-Sold
Post #607769 30th Sep 2021 10:27am
mickb
n anyone help I had a professional company install it for me . but it works intermittently. My phone recognises it is connected to auto android but the screen flickers black. then if i press the screen it comes on. Also the reversing is also working intermittently. Has anyone any suggestions when it works its brilliant but it just is not consistently working. Please need help Thanks
Post #608333 5th Oct 2021 3:29pm
get the install company to fix it.. ... - .- -.
Post #608339 5th Oct 2021 3:51pm
mickb
Stan,
the problem is they have never installed this before so they are unsure as to what is wrong as it works inconsistently. I got in the vehicle today worked fine. Got out when got back in it didn't work right away then it worked.
Post #608352 5th Oct 2021 4:43pm
ah, gotcha..
weegie might know if not then isnt there a forum for navtool? ... - .- -.
Post #608353 5th Oct 2021 4:49pm
if its intermittent i'm thinking maybe a loose connection..
try FAQ or live chat here,
https://www.navtool.com/techsupport.aspx ... - .- -.
Post #608355 5th Oct 2021 4:53pm
Weegie
I would think they need to redo the connections. It isn't a highly technical job to do. As Stan says, it rather points to connection problems.
Also, the quality of the leads is important.
When I was doing mine I disconnected everything a couple of times as there were some, minor, problems.
What are you using, the USB or the HDMI?
what do you mean the reversing is working intermittently? John
GAP iiD BT-Sold
Post #608357 5th Oct 2021 5:08pm
