Home > Technical (L322) > Stinking
Page 2 of 3 <123>
Dannnn
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Was up there last week in mine and had the same after crawling up the kirkstone pass at 2500rpm which it seems to love to do for some reason Laughing
I can't be sure if mine is oil or coolant but the cooler has been done on mine and still smells hot all the time
Post #629328 21st Apr 2022 6:20pm
Davlyn
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
JayGee wrote:
Davlyn wrote:
Perhaps I should add it’s a 4.4tdv8.
BTW your car seems to be a 2015 L405? This sub section is for the earlier L322.
Well spotted that man! I need to update that. Didn’t really get on with the L405 so went back to a L322.
Post #629332 21st Apr 2022 7:38pm
Davlyn
Have you had anybody take a look at it?
Post #629333 21st Apr 2022 7:39pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Many years back I had a 5 series with the ZF 6 speed. While at a zoo with the drive around “safari” section I was crawling with the rest of the cars and after a while i had a horrible smell in the car.
It was like rotten eggs, and later put it down to cooking the torque converter due to the slow speeds and inclines.
Given the first post describes lots of hills and slowness, is it possible the smell is the gearbox working too hot? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #629393 22nd Apr 2022 12:33pm
JayGee
If you are revving over 2500 rpm the 2nd turbo will kick in and if it’s not had the drain mod it will burn oil in the exhaust. 2012 TDV8 Vogue (L322)
Post #629468 22nd Apr 2022 10:24pm
Ffrr-lover
Davlyn…
How would you describe the smell? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #629477 23rd Apr 2022 7:16am
Davlyn
It just smells hot! Possibly slightly oily. It just seems hotter than it should be for the small amount of hard work it’s done.
Post #629545 23rd Apr 2022 7:29pm
Dannnn
Any updates on this?
Post #634089 8th Jun 2022 8:47pm
Davlyn
Nope... We did a run up to Oxford from Cornwall a couple of weeks ago. About 3/4hr into the journey I stopped off to grab some diesel. When I pulled up at the pumps I had a faint cloud of smoke emanating out from under the bonnet. By the time I realised what was going on I flipped the bonnet to get out and check, but it had almost dissipated. From the brief glimpse I did get it seemed to be coming from the back of the engine, I presume it must be something dripping onto the exhaust??
I just carried on with the journey with no problems.
I dropped it down to my local indy a few days after. He had a good look around and said all the usual suspect places seemed fine and everything seemed dry.
The RR is a second car so it sits around for weeks. I will try and make an effort to get out this weekend and have a better look.
Post #634103 9th Jun 2022 7:12am
DrRob
That does sound like oil cooler gaskets or the O rings leaking oil into the V but you've had a specialist check it who should know what to be looking for.
Engine cover off, pollen box off (2 x nuts), grab a small step and then peer down into V at rear and look for leaks around the cooler (sits under the oil filter). Look under the car too for oil on the bellhousing circular cross member. Even better if with engine undertray removed - oil can collect on it.
If you were nearer me I'd happily check it...If I'd have known I could have done it when I was down in Fowey last month Wink
Who is your specialist? Mark Kelly in Tavistock is good I hear.
I know of JLR Services, Shaun King, Trevecca, Steve Toyer Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #634104 9th Jun 2022 7:17am
Dannnn
Started to strip the manifold on top of mine this eve for a better look and spotted this underneath the oil cooler which was a shame considering I have an invoice for a replacement oil cooler not that long ago by the previous owner. Feed pipe on the back is dry. Is there anything else I should be checking around there that could be causing the smoking or is it pretty certain it's cooler related?
Not wishing to hijack this post but thought the pictures could be useful for the OP.
Post #634199 9th Jun 2022 7:05pm
Davlyn
Finally, found a decent independent that actually wanted to help me sort this problem out. Transpires the issue of the oil mist was the oil cooler gasket leaking. The 'hot' smell turned out to be a seized rear caliper.
So, 4 new discs, 2 sets of pads, two new rear calipers and the oil coiler gasket and she seems as good as new now, well other than a sticky starter motor that on occasions seems to want to stick. Guess that will be the next job...
Post #638049 28th Jul 2022 11:40am
DrRob
Good news! Looks like both collective suggestions were correct = caliper and cooler. Hive mind power Bow down
Who did the work for you down that way? Always good to add to my list of recommended specialists that I keep as Favourites on Google Maps Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #638062 28th Jul 2022 12:29pm
DrRob
Had my starter done too due to sticking. Used one from Advanced Factors. Fixed the issue Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #638063 28th Jul 2022 12:30pm
Davlyn
Josh & Clive @ LRD Southwest Ltd. Only a fairly small outfit but with a great levels of service.
Out of interest, was the starter motor replacement a big job?
Post #638068 28th Jul 2022 1:23pm
Page 2 of 3 <123>
