Home > Technical (L322) > Stinking |
Davlyn Member Since: 21 Nov 2011 Location: Sladesbridge, Cornwall Posts: 234 |
Well spotted that man! I need to update that. Didn’t really get on with the L405 so went back to a L322. |
21st Apr 2022 7:38pm |
Have you had anybody take a look at it? |
21st Apr 2022 7:39pm |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
Many years back I had a 5 series with the ZF 6 speed. While at a zoo with the drive around “safari” section I was crawling with the rest of the cars and after a while i had a horrible smell in the car.
22nd Apr 2022 12:33pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3188 |
If you are revving over 2500 rpm the 2nd turbo will kick in and if it’s not had the drain mod it will burn oil in the exhaust. 2012 TDV8 Vogue (L322) |
22nd Apr 2022 10:24pm |
Davlyn…
23rd Apr 2022 7:16am |
It just smells hot! Possibly slightly oily. It just seems hotter than it should be for the small amount of hard work it’s done. |
23rd Apr 2022 7:29pm |
Dannnn Member Since: 17 Jun 2021 Location: Oxfordshire Posts: 11 |
Any updates on this? |
8th Jun 2022 8:47pm |
Nope... We did a run up to Oxford from Cornwall a couple of weeks ago. About 3/4hr into the journey I stopped off to grab some diesel. When I pulled up at the pumps I had a faint cloud of smoke emanating out from under the bonnet. By the time I realised what was going on I flipped the bonnet to get out and check, but it had almost dissipated. From the brief glimpse I did get it seemed to be coming from the back of the engine, I presume it must be something dripping onto the exhaust??
9th Jun 2022 7:12am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4300 |
That does sound like oil cooler gaskets or the O rings leaking oil into the V but you've had a specialist check it who should know what to be looking for.
9th Jun 2022 7:17am |
9th Jun 2022 7:05pm |
Finally, found a decent independent that actually wanted to help me sort this problem out. Transpires the issue of the oil mist was the oil cooler gasket leaking. The 'hot' smell turned out to be a seized rear caliper.
28th Jul 2022 11:40am |
Good news! Looks like both collective suggestions were correct = caliper and cooler. Hive mind power
28th Jul 2022 12:29pm |
Had my starter done too due to sticking. Used one from Advanced Factors. Fixed the issue Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
28th Jul 2022 12:30pm |
Josh & Clive @ LRD Southwest Ltd. Only a fairly small outfit but with a great levels of service.
28th Jul 2022 1:23pm |
