Home > Maintenance & Mods (L322) > SGS trolley jack, opinions please
Bingo_123
I am not able to use side jacking points, due to the deployable sidesteps. been using the bottle jack.
which is a bit of a pain as it takes long time.
thats why was looking to buy a trolley jack to speed up the jacking up process.
Post #629079 19th Apr 2022 12:23pm
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
Yep - me too.
I just bite the bullet and take the steps off.
Is a right pain, but needs must.
Warwick 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #629080 19th Apr 2022 12:25pm
Gremlin500
Gremlin500 wrote:
For anyone still looking, I just ordered this Hawk 3Te one £30 off:-
https://www.ebay.co.uk/itm/164146100376?mk...media=COPY
Arriving Tuesday, I’ll post pics and let folks know if it’s any good, seems to look the part, must see if they do a seal kit tho’.
Idea
Arrived today, -suitably impressed, 535mm max. Lift, not used it yet! Currently this is better value than the SGS one, delivered in 3 days:
 “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #629143 19th Apr 2022 6:28pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
There’s a few places you can use once you e got a trolley jack, the central points can be a bit of a pain to access but once you’ve worked it out, you’ll have the front or back up in no time.
I don’t have deployable steps, but can you not lock them out to access the jacking points or chassis rails?
Post #629151 19th Apr 2022 7:23pm
Jools
Pretty sure deployable steps can only be locked in the stowed position.
In theory, you might attempt to get around this by keeping a door ajar to maintain the step in the deployed position.
In practice though I think the jack lifting arm will then probably foul the step.
Post #629172 19th Apr 2022 9:59pm
Gremlin500
Try searching elsewhere on here, the DSS’s have a jacking point built into their brackets, -you stow the steps, and jack under the stowed bracket using a notched adapter “puck” if using a proper 3Te trolley jack.
This is also covered by the workshop manual in the Wiki, read carefully!
Hope this helps, no need to deploy the steps, only deactivate. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #629188 20th Apr 2022 9:24am
Bingo_123
i think L405 deplyable sidesteps have a built in jacking point, no9t the L322 ones.
Post #629190 20th Apr 2022 9:54am
Gremlin500
@Bingo_123,
Sorry my bad, you are correct, of course this is an L322 thread, d-oh! Banging Head “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #629194 20th Apr 2022 10:11am
garyRR
I have the SGS 'large 4x4' kit with the trolley jack with the extension which seems well made (as do the axle stands).
Has ample lift to get the vehicle up however, the axle stands are too large to fit under the wishbone mounts when jacked.
The other thing is that the jack bar (the bar you pump with) isn't long enough to reach under the rear sub frame between the exhausts so, I end up having to jack from the rear jack points on each side instead.
So yeah, a bit if a mixed review from my perspective from SGS.
The other thing I found their service is poor. The manual says to check all parts for manufacturing defects before using and report if you find any. I put the jack on a completely flat surface indoors and one of the wheels was off the floor. I reported this to SGS immediately and they took over 3 months to get back to me (by which time I'd gone sod it and used it). They then had the audacity to say if they can't find a defect, I'd be liable for shipping. When their own product instructions say to report anything that doesn't look right!!!!
So yeah, do they look well made, yes. Did I find a manufacturing defect, yes. Would I use them again, No. 2015 Range Rover Autobiography 4.4 SDV8
Post #630391 2nd May 2022 11:17am
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
So I finally used my new shiny jack in anger and was disappointed to find that it has insufficient lift when using the central lifting point between the exhaust pipes. There is no space to use a block of wood but that may have caused instability any way because I was using the extension lifting pad.
But I got enough lift to get some axle stands in place and then used a pair of small trolley jacks to lift the lower arms to get the tyres off the ground.
I tried this at both off road height and normal height, but did not try access height due to access issues under the car.
So three trolley jacks to get both wheels off the ground at the same time, a real pain but it did the job
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #631352 11th May 2022 11:22pm
