Home > Maintenance & Mods (L322) > SGS trolley jack, opinions please |
Kiss My Carbon Footprint Member Since: 19 Dec 2020 Location: Milton Keynes Posts: 119 |
Yep - me too.
19th Apr 2022 12:25pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1429 |
Arrived today, -suitably impressed, 535mm max. Lift, not used it yet! Currently this is better value than the SGS one, delivered in 3 days:
19th Apr 2022 6:28pm |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 282 |
There’s a few places you can use once you e got a trolley jack, the central points can be a bit of a pain to access but once you’ve worked it out, you’ll have the front or back up in no time. I don’t have deployable steps, but can you not lock them out to access the jacking points or chassis rails? |
19th Apr 2022 7:23pm |
Jools
19th Apr 2022 9:59pm |
Try searching elsewhere on here, the DSS’s have a jacking point built into their brackets, -you stow the steps, and jack under the stowed bracket using a notched adapter “puck” if using a proper 3Te trolley jack.
20th Apr 2022 9:24am |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 172 |
i think L405 deplyable sidesteps have a built in jacking point, no9t the L322 ones. |
20th Apr 2022 9:54am |
@Bingo_123,
20th Apr 2022 10:11am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
I have the SGS 'large 4x4' kit with the trolley jack with the extension which seems well made (as do the axle stands).
2nd May 2022 11:17am |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 579 |
So I finally used my new shiny jack in anger and was disappointed to find that it has insufficient lift when using the central lifting point between the exhaust pipes. There is no space to use a block of wood but that may have caused instability any way because I was using the extension lifting pad.
11th May 2022 11:22pm |
