![]() | Home > Maintenance & Mods (L322) > SGS trolley jack, opinions please |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 608 ![]() ![]() ![]() |
I've been looking for a trolley jack to replace my old one.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1310 ![]() ![]() ![]() |
I thought it looked like one of them short chassis ones but it is 620mm long so I'd say it looks a good one Dave. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I recently needed a jack that would work on my Rangie, and my sons m sport Bmw which is a |
Just to finish this I purchased the SGS jack.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1691 ![]() ![]() ![]() |
………… “If it ain’t broke, don’t fix it” -where’s the fun in that? |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 173 ![]() ![]() ![]() |
Hi bigbo, I also looked at the same jack few weeks ago as the 3t one wasn't in stock.
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 257 ![]() ![]() ![]() |
Also on the lookout for jack and axle stands. Is this package suitable?
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 296 ![]() ![]() ![]() |
It’s what I’ve got, works a treat. Get yourself a rubber pad to fit in the jacking point and you’re good to go, pads available on the bay for peanuts |
Kiss My Carbon Footprint Member Since: 19 Dec 2020 Location: Milton Keynes Posts: 130 ![]() ![]() ![]() |
As Jules says, should be fine.
Thanks JoolsB and Kiss My Carbon. Re the Griff, I have a Halfords low profile but as it's 20 years old not sure I can trust it to lift the L322. 2011MY 4.4TDV8 Autobiography Baltic Blue
But this jack has max lifting height as 465mm, is it sufficient to lift the ffrr.
Lifts mine, get the FF in off road height and open a door and it’ll lift the wheels from the jacking point, if you’re just doing a quick wheel change then jack it under the suspension arm.
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 134 ![]() ![]() ![]() |
Wouldn’t access height be better than off road height? |
Lance,
