![]() | Home > Maintenance & Mods (L322) > 4.4 TDv8 coolant leak- plastic connection? |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
The hose you refer to comes from the bottom of the radiator and feeds onto the thermostat housing beyond the silver clip. That clip may have lost tension and allowed the pipe to move back a little. Inside the connector is an o-ring. It's a similar set up to the throttle body inlet connector and there has been at least one occurence of that particular clip allowing such a faillure, albeit in the air inlet.
GGX Member Since: 31 Jul 2013 Location: North Wales Posts: 61 ![]() ![]() ![]() |
Thanks - I’ll search wiki
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Richard, if they are the same size as the connector on the oil cooler, then they are.....
GGX
Mike (Baltic Blue)
Nick83 Member Since: 17 Mar 2022 Location: Devon Posts: 6 ![]() ![]() ![]() |
Hi chaps, just dragging up an older post but I seem to have a coolant leak in exactly the same place and have some crystallisation around the end of the hose.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Nick, did you find out the correct size for the o-ring in that hose in the end? I think we have exactly the same leak and wanted to pick one up before I jumped in. Looks allot easier to change the o-ring than the hose.
Hi Tom,
[quote="TJH1985"]Nick, did you find out the correct size for the o-ring in that hose in the end?
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1260 ![]() ![]() ![]() |
I've got all mine stripped down today, doing pulleys, alternator and water pump,
Hi Kev,
Thanks Nick,
No problem Kevin!
