![]() | Home > My Range Rover > Back with another Supercharged |
Jacckk Member Since: 31 Dec 2015 Location: Durham Posts: 18 ![]() ![]() |
I'm looking at doing some similar rustproofing whilst I've got some stuff removed (and on my P38).
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3146 ![]() ![]() ![]() |
That's right.
If you are going to use epoxy or something to paint your subframe, make sure you’ve got a decent tap set as the bolt holes in the subframe will need cleaning out once it’s dried off. |
A pallet left Birmingham at 3pm yesterday and I was told to expect it Thursday or Friday. At 10.15 this morning I got a call from a delivery guy asking how to find us…
Last weekend when I was trying to change a CV gator on the rear shaft as it was torn I could not for the life of me get the CV joint off the shaft.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1268 ![]() ![]() ![]() |
Worth while popping the gaiters off and checking for grease if your old ones were dry? |
My old shaft had a blob of epoxy over a tear in the gator which is why it was short.
Tonight I’ve reassembled the diff with the locking motor.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
All looking good - you may have done it but take the inner lower cover up the upper boot lid and load it up with bilthammer - apparently they rust from the inside out. When I got my new lid painted that’s the first thing I did Current stable:
Are you talking about the cup that sits over the diff seals on the shafts?
Tonight saw the rear diff motor cleaned up - good job I gave it a proper look over as it had little shiny metal particles in it. This makes sense as the lad I spoke to today was the lad who stripped my diff down - he said the bearings in it were worn.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Tell you what David i am so excited for you when this is all back together and on the road again what a journey!! also i am super envious of the facilities you have to work from. |
Thank you |
Argggggghhh!
