![]() | Home > My Range Rover > Back with another Supercharged |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Time for a bit of chillaxing while you wait for the bits to arrive. You'll probably find something to do on your soon to be perfect SC though.😉 Previous cars:
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3192 ![]() ![]() ![]() |
Fuel tank guards finished off this evening.
2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior |
Does anybody remember the film Billy Madison with Adam Sandler?
Excitement began to build at this point…
After unpacking and unwrapping I was smitten to see these…
Just a shame when they’re fitted you’ll never be able to see them… just like everything else I’ve done to this car! 🙈 Big thanks to Piet who adverised the tools to remove the crankshaft pulley and a set of timing tools for the 4.2 today which will shortly be arriving ![]() David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior |
Piet Member Since: 22 Mar 2017 Location: Maasdam Posts: 199 ![]() ![]() ![]() |
David,
Thanks Piet
Here’s the old bracket with the old bolts. Pretty evident why I wanted to change them!
The old bolts weren’t going to grip with anything so I cut a slot in them with the angle grinder and removed them very easily with a flat blade screwdriver.
Sensors mounted to new brackets with new stainless self tapping screws.
Irritatingly the parts catalogue lists the wrongs screws for mounting the height sensors to the brackets but I had some that have done the job ![]() Everything back in situ.
I’d bought new unions and olives where the air pipes go into the bags. When I’d removed them I wasn’t happy as the pipes were bruised where the olives had been. Due to a slightly bulge in the pipe behind the union I couldn’t trim them either so I’ve cut the ends off the pipes and joined them this afternoon. Subframe is now finished other then the anti roll bar which I’ll refit when it’s on the car due to the weight making it more awkward. Zip ties are holding the wishbones together so that there’s more clearance for refitting and to stop it stretching the airbag.
I then wheeled it on the toolbox to the front of the shed where I lifted the frame in the air with the digger and placed the diff on the toolbox.
I then lowered the frame onto the diff.
And then fitted the bolts through the new bushes into the diff.
I’ve got a few other things I could do with looking at just now so I think I’m going to leave refitting this back to the car until tomorrow. David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior Last edited by dhallworth on 9th Apr 2022 11:29pm. Edited 1 time in total |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Amazing, just amazing! |
Thanks Philip.
During:
After:
By tomorrow evening, the list of work done only to the rear will be: Painted the whole assembly with Bilt Hamber Epoxy Mastic. Fitted 21 new bushes - 4 main subframe bushes, 4 upper wishbone bushes, 4 lower wishbone bushes, 2 toe control arm bushes and 3 differential bushes, and 2 bushes in each hub which aren’t pictured yet. Fitted 2 new toe control ball joints on the arms. Fitted 2 new wheel bearings, Fitted new brackets to the height sensors on the rear suspension. Replaced sections of air suspension pipework. Fitted 2 new handbrake cables. Fitted new brake disc back plates. Fitted new handbrake shoes and springs. Fitted new sliders to rear calipers. Fitted EBC Greenstuff rear pads. Wire brushed, treated and painted rear brake calipers. Wire brushed, rust treated, zinc painted and epoxy mastic painted the underside of the car. Wire brushed, rust treated and painted rear driveshafts. Wire brushed, rust treated and painted anti roll bar and brackets. Removed, wire brushed, rust treated, painted and refitted fuel tank guards. Rear airbags and shock absorbers have only been on the car since November and have done around 1000 miles. When you see the list it doesn’t sound like a lot but at the moment it feels like it’s been a labour of love! David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
when can i drop mine off...................... |
Subframe is now back in
This is how she was sitting in the workshop earlier…
Unfortunately, it’s not quite as far on as the pictures would suggest… The workshop manual says to tighten the upper and lower wishbone bolts with the car at normal ride height. However, it also says that to do the upper wishbone bolts you need to drop the subframe. I noticed when remounting the subframe earlier that if I left the driveshafts out I could reach the nuts and bolts with a spanner and the torque wrench so I loosely fitted the hubs, fitted the wheels, torqued the bolts and then removed the wheels and put it back on axle stands. Tomorrow evening I’m going to rebuild the hubs, and get everything back together. Have come up with a plan so that I can get things aligned as best I can before taking it in for tracking too. David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior |
If you saw my parts bill you’d maybe not be asking! I’ll post a breakdown when I’m finished but I’m about £3K in 2 months, if I include the air springs, and shock absorbers I did in November it’s cost me £4K for the full suspension rebuild. I’m really hoping it drives like a new L322 would have done when it’s finished! David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior |
Rear anti roll bar was painted on Sunday and refitted tonight along with new drop links. Irritatingly, despite it being very simple to fit it required removing one of the air springs as it curves around them. Not a massive job thankfully.
Rear drive shafts are now both installed. Interestingly the workshop manual states to plaster the splines of the driveshafts with Loctite to stop the splines moving in the diff and to leave it for at least 24hrs before moving it. No problems there for me then ![]() Rear hubs were then installed and the handbrake shoes built back up.
I couldn’t remember which side the bolt faces on the toe control arms so eye balled the underside of the other L322 this evening and got them back in too. It’s booked in for a full 4 wheel alignment on Tuesday with the local JLR specialist so I’ve got a firm deadline to get it mobile again now! David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior |
Yea, I’ve done all of my bushes with the stuff and it looks like I’ve barely used any out of the bottle.
Unfortunately, it’s a sod to get to as it hides behind a heat shield right beside the NS valve cover which has an air con pipe running right beside it. I’ll get the brakes bled out tomorrow evening and will then get the car started and pressurise the cooling system in the hope I can see where the leak is. David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior |
With it being a bank holiday weekend I was going to order the 3 parts... 2 hoses and 1 pump just to change the lot out so I can get it back on the road next week...
Today saw the brakes bled, both diffs filled with oil and the transfer box oil changed again after 4k miles since the brand new transfer box went in last summer. Quite pleased I changed it as it was massively darker despite only being 8 months old.
Anyway, 2 new brake Flexi's have been ordered this evening so hopefully we'll see them this week. David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior |
