Home > In Car Electronics (L322) > Bluetooth Module Failure?
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
My phone connected fine to the internal bluetooth system on my '11 TDV8 for the first six months or so but suddenly it can no longer see the bluetooth module to connect. I'm guessing the unit might have failed ut I have no idea how to locate it or work out what is going on. Any ideas?
Post #626438 18th Mar 2022 3:16pm
Mike Edwards
Any ideas?
Post #626758 22nd Mar 2022 9:56pm
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
Search the forum and I expect you’ll find something on it. I vaguely recall reading that it’s in one of the cubby holes in the boot.
Post #626763 22nd Mar 2022 10:47pm
Mike Edwards
Now my display keeps switching between the various options without any other input. The Bovee connected music stops and restarts frequently, i.e. every few seconds. It does the same with the Bovee unplugged. Give it a while and it returns to working normally. Until the next time.
Any idea what might cause this, particularly after losing the direct bluetooth phone connection recently also?
Post #627172 28th Mar 2022 9:41pm
Mikebob
South Africa 2007 Range Rover Supercharged 4.2 SC V8 Java Black
your Bluetooth module has died, probably from water damage. left boot panel is where it is. replace it and all will be well
Post #627174 29th Mar 2022 5:14am
essex boy
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Check the terminal connectors mine had turned a bit blue due to corrosion
Post #627260 29th Mar 2022 8:30pm
essex boy
my one was the top unit above dvd player marked nokia
Post #627261 29th Mar 2022 8:32pm
Mike Edwards
Thanks. I’ll take a look.
Post #627280 29th Mar 2022 10:24pm
Mike Edwards
Interesting that the car is also showing:
U0128-00 (2E) Lost communication with parking brake control module
U0159-00 (2F) Lost communication with parking assist control module
Not sure about the first one but the parking assist control module appears to be pretty close to the bluetooth module. Could the two problems be related?
Any suggestions as to where to start looking?
Post #628225 9th Apr 2022 8:50pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Hi the parking aid module is in the right hand cubby, the BT module is in the left cubby with all the audio kit. So probably not related.
The BT module is on the top of the stack of audio equipment. To check if its the BT module causing your issues you need to remove it from the MOST ring and connect a MOST bypass connector (available on eBay) so that the MOST ring is complete. If this clears your problem then you have proved that the BT module is faulty.
Mine is a MY06 which had a Nokia module but I swapped it for a 2010 module, hopfully this picture will help a little, the BT module is the one at the top with the orange MOST cable
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #628231 9th Apr 2022 11:25pm
Mike Edwards
Not on my car it’s not. The parking aid module is bolted vertically to the bulkhead about six inches down from the CD player and Bluetooth module.
Post #628232 9th Apr 2022 11:32pm
bigbo
That's odd, my info comes from the manual and I cant imagine that a previous owner moved it. So very strange.
However the rest of my advice stands, isolate the BT module first, if that does not work then isolate each module on the MOST ring until you find the fault. Assuming of course your fault is caused by one of those modules.
MG TF 2003
Post #628234 9th Apr 2022 11:38pm
harleyman
Spain
You could check the battery
My car with low battery makes that you can not find the Bluetooth module 2012 Range Rover 4.4 tdv8 Autobiography
Post #628534 13th Apr 2022 8:55am
Mike Edwards
The battery reads 12.0 - 12.2V with the engine off and 14.0 - 14.4V with the engine running.
I do seem to have an number of other intersting issues though.
The IID Tool can't see the handbrake control module despite the handbrake working fine.
IAlso, my radio is also switching between options and I have absolutely no idea why some are enabled then disabled then all seems fine for a bit then it starts flickering again.
Any and all ideas welcome...
Post #628784 16th Apr 2022 12:38pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
can bus or most bus issue
Post #628816 16th Apr 2022 8:32pm
