Home > In Car Electronics (L322) > Bluetooth Module Failure? |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 |
Any ideas? |
22nd Mar 2022 9:56pm |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 119 |
Search the forum and I expect you’ll find something on it. I vaguely recall reading that it’s in one of the cubby holes in the boot. |
22nd Mar 2022 10:47pm |
Now my display keeps switching between the various options without any other input. The Bovee connected music stops and restarts frequently, i.e. every few seconds. It does the same with the Bovee unplugged. Give it a while and it returns to working normally. Until the next time.
28th Mar 2022 9:41pm |
Mikebob Member Since: 10 Jun 2019 Location: Pretoria Posts: 10 |
your Bluetooth module has died, probably from water damage. left boot panel is where it is. replace it and all will be well |
29th Mar 2022 5:14am |
essex boy Member Since: 21 Jan 2017 Location: essex Posts: 207 |
Check the terminal connectors mine had turned a bit blue due to corrosion |
29th Mar 2022 8:30pm |
my one was the top unit above dvd player marked nokia |
29th Mar 2022 8:32pm |
Thanks. I’ll take a look. |
29th Mar 2022 10:24pm |
Interesting that the car is also showing:
9th Apr 2022 8:50pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 579 |
Hi the parking aid module is in the right hand cubby, the BT module is in the left cubby with all the audio kit. So probably not related.
9th Apr 2022 11:25pm |
Not on my car it’s not. The parking aid module is bolted vertically to the bulkhead about six inches down from the CD player and Bluetooth module.
9th Apr 2022 11:32pm |
That's odd, my info comes from the manual and I cant imagine that a previous owner moved it. So very strange.
9th Apr 2022 11:38pm |
harleyman Member Since: 04 Feb 2021 Location: Madrid Posts: 73 |
You could check the battery
13th Apr 2022 8:55am |
The battery reads 12.0 - 12.2V with the engine off and 14.0 - 14.4V with the engine running.
16th Apr 2022 12:38pm |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 162 |
can bus or most bus issue |
16th Apr 2022 8:32pm |
