Home > In Car Electronics (L322) > Bluetooth Module Failure? |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 |
Curious situation with the Bluetooth module. I bought a MOST bypass connector and unplugged the Bluetooth module and the radio started behaving itself once again. I pulled the module apart and found absolutely nothing obviously wrong so I put it back together and plugged it all back in. Clearly the radio didn't work but when I unplugged it again and fitted the bypass module the radio refused to play. No idea what happened or why. All rather confusing. |
1st Jun 2022 9:48pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
Sounds like disconnecting both the MOST fibre and copper cable then fitting the MOST bypass is telling the head unit not to bother looking for a BT unit as it's not there. That allows the radio to work.
2nd Jun 2022 7:35am |
That doesn’t explain why the bypass worked fine at the first attempt and then failed to work on subsequent attempts. |
2nd Jun 2022 8:33am |
With the bluetooth ,module bypassed the only permanent error I'm getting is that the Parking parking sensor control module is missing. After a bit of driving it usually adds the parking brake control module to that list which is rather bizarre as the parking brake continues to work. The latest error is that the DAB unit has a system internal failure.
23rd Jun 2022 8:10pm |
Not the username I wanted Member Since: 27 Feb 2023 Location: Tasmania Posts: 6 |
G'day Mike,
27th Feb 2023 12:25am |
Interesting. Thanks.
27th Feb 2023 2:24pm |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
hi bigbo have you done any link-up on the rse module I see you have 3 cables coming out of your top connector oggy new vehicle purchase 2007 supercharged 4.2 java black .sand leather vogue se trim previous cars . range rover classic 200 tdi discovery 1 200 tdi freelander 2 2008 hse discovery 1 300 tdi p38 4.0 ltr man r380 ex royal support vehicle on v5c discovery td5 man off roader |
27th Feb 2023 3:41pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 569 |
There is only two optical cables connected to the RSE module, the third that is visible is running behind to the TV tuner.
27th Feb 2023 3:57pm |
optical illusion very good i can see it now new vehicle purchase
27th Feb 2023 4:07pm |
BigEnglishWagon Member Since: 30 Jun 2020 Location: Wellington Posts: 9 |
Hello bigbo,
4th Aug 2024 10:55am |
Sorry cant help as I do not have an iphone. My phone connected day 1 and has never failed. Range Rover 4.2 Supercharged 2006
4th Aug 2024 2:47pm |
Thank you for your reply.
5th Aug 2024 4:18am |
