Home > My Range Rover > Back with another Supercharged |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3740 |
David,
14th Mar 2022 9:03am |
I think dementia must be to blame , apologies, it is Diesel Dave who was a BT mechanic.
14th Mar 2022 12:32pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3030 |
Thanks Mike, the calipers were actually pretty easy to do I rubbed then down with these on the end of a Snap On Polish & Prep tool.
14th Mar 2022 4:38pm |
Was thinking about the subframe bushes today as they’re huge and are an incredibly tight fit into the subframe. After a big of Googling it turns out they’re the same bushes as in the rear subframe on the BMW X5.
14th Mar 2022 10:03pm |
Changed my mind again… Several reasons for doing so…
15th Mar 2022 9:12pm |
Been a busy evening tonight…
18th Mar 2022 12:19am |
Managed to get a few more jobs done today.
23rd Mar 2022 12:51am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
David, looking at your front brake callipers... Do you have own any Paint Protection Film? Cut a piece to fit the front panel of your caliper where you have fitted the BREMBO decal and voila your decal will never peel |
23rd Mar 2022 12:57am |
That’s a great idea! Thanks Craig!
23rd Mar 2022 1:00am |
You May be able to pan in on mine and see the PPF?
23rd Mar 2022 1:07am |
Is it easy enough to apply? I’ve seen video’s online that suggests soapy water and a rubber blade or similar to spread it smooth. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
23rd Mar 2022 1:11am |
Make sure to only buy 3M stuff David... Tis the best |
23rd Mar 2022 1:13am |
Yes, very easy... Spray bottle with clean water, soak the area, apply and squeegy out... |
23rd Mar 2022 1:15am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
hats off Dave fantastic job 2012 Vogue 4.4 TDV8 - Current
23rd Mar 2022 9:00am |
