![]() | Home > Maintenance & Mods (L322) > MAP Sensor A |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2572 ![]() ![]() ![]() |
Check the right top intercooler hose for a split. |
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 92 ![]() ![]() ![]() |
Thanks GraemeS, not wishing to appear stupid but.....
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
As GraemeS says check intercooler hoses. here is my recent fail and new hose fitted. After I sorted the right side the left one split a week after. You can successfully make a good temporary repair with self-amalgamating hose tape. If you look at my 4th photo, in front of the new hose engine side jubilee clip there is an electrical plug, that is the map sensor. It can easily be removed and cleaned with throttle body cleaner, they can get covered in crud
thank you guys guess my day off tomorrow will involve looking for split pipes and part numbers |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3198 ![]() ![]() |
A HIGH pressure smoke test will examine all your joints, including inlet manifolds which are known to crack. You can't see them by eye. |
