Home > Maintenance & Mods (L322) > MAP Sensor A
Tiprat
MAP Sensor A
Good morning everyone, so pulling onto the motorway yesterday from the services up an incline, light throttle load, not trying to make the RR drop to a lower gear or anything and all of a sudden i get the dreaded "bing" restricted performance loss of power ect. Pull onto hard shoulder, turn everything off. leave for a minute or so turn on and drive away happily for the rest of the day.
Get to my destination put my reader on it and it says MAP Sensor A boost sensor correlation. Now its done this a couple of times over the time ive had it, and it did it once or twice on the previous owner (a friend). So first time i cleaned the sensor with brake cleaner, and when it did it last time i swapped the sensors over to see if it would come up as sensor B...But no its come back up with sensor A again Rolling Eyes
So can anyone give me some pointers as to where to look too next?
regards
Tiprat. Borrowed Grey 2002 3d 204k for a year
Now own a 2007 Java black Vogue SE 3.6TDV8 160k
Post #625670 8th Mar 2022 9:28am
GraemeS
Check the right top intercooler hose for a split.
Post #625731 8th Mar 2022 7:55pm
Tiprat
Thanks GraemeS, not wishing to appear stupid but.....
Top right looking from the bumper or from the steering wheel?
If I find a split is it worth buying a silicon tube over rubber given the age and milage of the RR?
Regards Borrowed Grey 2002 3d 204k for a year
Post #625759 9th Mar 2022 8:45am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
As GraemeS says check intercooler hoses. here is my recent fail and new hose fitted. After I sorted the right side the left one split a week after. You can successfully make a good temporary repair with self-amalgamating hose tape. If you look at my 4th photo, in front of the new hose engine side jubilee clip there is an electrical plug, that is the map sensor. It can easily be removed and cleaned with throttle body cleaner, they can get covered in crud
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #625760 9th Mar 2022 9:02am
Tiprat
thank you guys guess my day off tomorrow will involve looking for split pipes and part numbers Very Happy Thumbs Up Borrowed Grey 2002 3d 204k for a year
Post #625764 9th Mar 2022 9:38am
Dolphinboy
A HIGH pressure smoke test will examine all your joints, including inlet manifolds which are known to crack. You can't see them by eye.
Post #625770 9th Mar 2022 10:44am
