![]() | Home > In Car Electronics (L322) > Fitting my Naviplus / air play unit |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I wouldn’t think the lvds messes with that. It is likely the aux port indeed. |
davethomas83 Member Since: 12 Dec 2015 Location: Gloucester Posts: 30 ![]() ![]() ![]() |
Good evening all - just started my NaviPlus journey today ( 2012 tdv8 4.4 Single View Screen ) . . . Suffice to say not completely straight forward.
I don’t know the dip switch settings for a single view screen nor whether the dipswitch is the only difference.
Thanks Bl4ckD0g,
Good luck. My gut feel thinks it’s the ground as they skipped that part in the manual. And also if one isn’t used to print board connections it requires inserting those connectors with more force and depth than one can be comfortable with.
Thinking about it - have I been foolish I’m not disconnecting the battery ?
Oops yes, definitely disconnect. And wait 20 or so minutes before you do that. Blimey you are lucky getting the airbag out without taking the power off eeeeekkkk
So, battery disconnect hasn’t helped ( although did clear the airbag warning light 😂 ).
Oh yours looks fairly different that my dual view system. I’ll take a look later today when I have access to a big screen.
Perhaps you disconnected it just at the time photo was taken but if not you have to fix that to the same board. |
This is the ldvs cable, is that not how I should earth it ?
I earthed mine to the actual print board screw inside the enclosure. That is what naviplus told me. |
Ahh ok - I’ll give that a good next then.
Hmmmm I'm trying to look at the big screen, but yours is significantly different. Amazing for just dual vs single view.
