Home > Technical (L322) > "special programs off message" help please |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3203 |
A failing battery can throw a lot of faults like these. What’s the voltage after shutdown and in the morning before starting? As you are getting similar faults from other system ECU’s this is a strong indicator. 2012 TDV8 Vogue (L322) |
30th Jan 2022 9:03pm |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2288 |
Thanks, yes I know what a failing battery can do, this one is pretty new and the charge is around 14.5 or 15. This whole thing is really a communication fault due to the rlcm or can bus faillure, but I haven’t got a clue what to do… |
30th Jan 2022 9:39pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
i think you mean 'special programs off' Robert ???
30th Jan 2022 10:13pm |
Thank you Stan,
31st Jan 2022 11:03am |
regards from a wet and foggy France |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
Try disconnecting the battery and doing a reset by holding the leads together for a minute or so.
31st Jan 2022 11:18am |
Thanks Mike, did that yesterday according to the procedure in the wiki. Didn't help.... |
31st Jan 2022 11:24am |
double check all the connections around the battery area and make sure they are tight... ... - .- -.
31st Jan 2022 3:51pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
First thing I would check is whether the RLCM is plugged in, clean the connector and trace the wiring that everything is ok. Perhaps also check whether the heights are calibrated correctly as it may just have thrown it out of tolerance.
31st Jan 2022 4:58pm |
Thanks I’ll work down the list and keep you updated. First I got to find the module … |
31st Jan 2022 5:43pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
can you list the actual codes the "U" codes are normally ghost codes due to something else in the chain failing.
31st Jan 2022 6:20pm |
Thank you Jayk69
1st Feb 2022 9:51pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
I had this problem and discovered that the front tracking was way out.
2nd Feb 2022 7:56pm |
For the specialists amongs us hereby the messages in:
3rd Feb 2022 3:49pm |
