![]() | Home > Technical (L322) > Auxillary belt and Pulley replacement - MY12 TDV8 |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Started tackling this today, jeeze this is going to be fun |
As I'm removing coolant hoses I look may aswel change it all.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Personally i use Halfords ready mixed stuff.
Thanks jayk69, just the Halfords silicate stuff? Don’t need OAT version?
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
I bought 5 litres of genuine coolant, STC 50530, from my local indy for £18 + vat. Just been looking on the net and I recon they have only charged me for 1 litre. Others are selling 5 litres for about £60+. Thought it was a bit cheap. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3218 ![]() ![]() ![]() |
@rjh
Thanks for confirming dolphinboy,
This is turning into an absolute mare of a job! Took best part of 4 hours to get 3 bolts out today. |
Brerfox Member Since: 22 Dec 2021 Location: Wales Posts: 16 ![]() ![]() ![]() |
Well today is not a good day. this being my first post |
Ok so all done wasn't too bad. only problem now is I have a restricted performance warning come on so in the morning will be back on it checking all my connections, wet, dry, and electrical |
Sharpy1980 Member Since: 20 Nov 2016 Location: Kent Posts: 55 ![]() ![]() ![]() |
I had the same issue a couple of months ago heard a flapping noise and steering went heavy I found bits of shredded belt wrapped around everything, typically I was on holiday and had to do mine outside our caravan on a holiday park with just some basic tools not a fun job at all especially getting that little belt on, I did mine without removing the fan cowl which was a struggle but I managed it. Luckily I keep a gap iid in the glovebox to clear all the warnings after (I had the same as you) but they never returned after clearing L322 4.4 TDV8 Current
Yep also got the gap iid tool, cleared the faults there were loads from no power to faulty suspension the only one that comes on now is the egr temp sensor, which was the only one before the belt shred. when I drive 100mtr the restricted performance comes back on but no additional codes, so I'm hoping its one of my connections |
