Home > Technical (L322) > TDV8 4.4 2011 Throttle Body Motor clicking |
Sarchopperman Member Since: 11 Aug 2017 Location: Aberdeenshire Posts: 33 |
Car had been running well up to the point it stopped. Engine switched off ........ loud clicking noises coming from throttle body. Car went into limited power mode.
20th May 2018 6:01pm |
Didn't mention that throttle valve does not move.
20th May 2018 7:15pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 791 |
If you replace the throttle body, please take the old motor out and post pictures and any part numbers stamped on the motor body. These motors are available as a separate part for lots of vehicles if you know which one. This could help others in the future.
21st May 2018 2:00am |
Yes, I will do that. I did try to remove the motor cover but the first screw snapped and so I stopped there. This would indicate that replacing just the motor might be problematic. RR L322 TDV8 4.4 SE 2019 to present
21st May 2018 4:52pm |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 |
I had the same fault previously, was replaced under warranty by dealer.
21st May 2018 6:05pm |
Yes, that’s exactly what it sounds like. Thank you ... i’m encouraged that my diagnosis might be right.😀 RR L322 TDV8 4.4 SE 2019 to present
22nd May 2018 6:49pm |
26th May 2018 8:50am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3200 |
Worth keeping the throttle clean to stop the strain on the gears - it's on my list.... 2012 TDV8 Vogue (L322) |
1st Dec 2021 12:41pm |
Brian McColm Member Since: 23 Apr 2024 Location: Lochmaben Posts: 6 |
I have the same symptoms as sarchopperman, I went and bought a new throttle body and fitted it but still it will not start and still have the clicking coming from the throttle, my Indy is thinking it’s a wiring issue as he is getting different voltage from some of the wires going to the throttle, has anyone any thoughts or has experienced this problem before? |
17th Aug 2024 8:26am |
