Home > Technical (L322) > TDV8 4.4 2011 Throttle Body Motor clicking
Sarchopperman
United Kingdom 2011 Range Rover Vogue TDV8 Epsom Green
Car had been running well up to the point it stopped. Engine switched off ........ loud clicking noises coming from throttle body. Car went into limited power mode.
Throttle body motor unplugged ....... noise stopped. Noise also stops after total ignition shutdown a couple of minutes after switching off.
With ignition on and engine running or not I get the same symptoms.
Ran SDD diagnostics which is pointing me to a lost signal from the EGR controller.
Removed throttle body a cleaned it ....... no change when refitted.
Removed fault code and power limiting disappeared. Throttle body motor still chattering away so reluctant to drive.
Any thoughts? Is this a failed throttle body motor? Or the egr valve controller? Or something else?
Help welcome RR L322 TDV8 4.4 SE 2019 to present
RR L322 TDV8 4.4 - 2016 to present
Discovery 2 TD5 - 2010 to 2016
Discovery 1 - 2000 to 2010
Post #478979 20th May 2018 6:01pm
Sarchopperman
Didn't mention that throttle valve does not move.
This leads me to think that EGR controller is trying to move it. UTC not getting any throttle valve position information.
I am going to replace the throttle body first. RR L322 TDV8 4.4 SE 2019 to present
Post #478987 20th May 2018 7:15pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
If you replace the throttle body, please take the old motor out and post pictures and any part numbers stamped on the motor body. These motors are available as a separate part for lots of vehicles if you know which one. This could help others in the future.
https://www.aliexpress.com/item/throttle-c...autifyAB=0 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #479008 21st May 2018 2:00am
Sarchopperman
Yes, I will do that. I did try to remove the motor cover but the first screw snapped and so I stopped there. This would indicate that replacing just the motor might be problematic. RR L322 TDV8 4.4 SE 2019 to present
Post #479065 21st May 2018 4:52pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
I had the same fault previously, was replaced under warranty by dealer.
Mine sounded like a cog slipping. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #479068 21st May 2018 6:05pm
Sarchopperman
Yes, that’s exactly what it sounds like. Thank you ... i’m encouraged that my diagnosis might be right.😀 RR L322 TDV8 4.4 SE 2019 to present
Post #479150 22nd May 2018 6:49pm
Sarchopperman
Throttle body replaced with genuine LR part (number LR020694) priced at £108 ....... FIXED!!!!!!
So, if you have the following symptoms:
1. Clicking from the top front of your engine
2. Clicks with engine running or off
3. Engine goes into limited power mode
It could be that a plastic gear in the throttle body has stripped.
I believe that throttle body repair kits are available for other car makes but looking at the price it is easier and more cost effective to just replace the throttle body. RR L322 TDV8 4.4 SE 2019 to present
Post #479392 26th May 2018 8:50am
Darrell Senior
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Mariana Black
Have the same problem; sure the new throttle body will work. However part from LR is 4 weeks back order. Had to pay £285 from some enterprising Bayer.
Post #614356 1st Dec 2021 11:04am
JayGee
Worth keeping the throttle clean to stop the strain on the gears - it's on my list.... 2012 TDV8 Vogue (L322)
Post #614368 1st Dec 2021 12:41pm
Brian McColm
2010 Range Rover Vogue SE TDV8 Baltic Blue
I have the same symptoms as sarchopperman, I went and bought a new throttle body and fitted it but still it will not start and still have the clicking coming from the throttle, my Indy is thinking it’s a wiring issue as he is getting different voltage from some of the wires going to the throttle, has anyone any thoughts or has experienced this problem before?
Post #698231 17th Aug 2024 8:26am
