Home > Maintenance & Mods (L322) > Rear washer leak repair - the cheaper option!
Page 5 of 5 <12345
FrankN
Germany 2004 Range Rover Vogue Td6 Bonatti Grey
@wayneg
What jet is it you are using?
Hello,
this jets are from a little Iveco Truck , but many other cars have such a jet, my jaguars have the jets on the front , so I come to this idea
Regards
Frank
Post #460823 14th Dec 2017 8:50am
uzp315
FrankN I like it. More for the fact that it will probably last the lifetime of the car than for it's aesthetics.
When you say "jets" - can you explain a little more for me please?
I've now done the OP's repair with the oil seal. If it lasts, great, if not I will do a FrankN repair.
Thanks
Mark
Post #461163 17th Dec 2017 4:32pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Unfortunately I've left it too late to do this fix and the wiper motor is now totally furbared so it's going to have to be replaced. However, I've noticed that the rear washer pump no longer seems to work. Is there a defeat device that would prevent the washer motor from working if the wiper doesn't work? Fuses are ok. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #461164 17th Dec 2017 5:05pm
FrankN
Hello Mark ;
I have my Jet from an old Truck, but this here is like the same methode .
https://www.ebay.de/itm/Waschduese-Duese-S...1338119324
Post #461228 18th Dec 2017 9:39am
ian_w
Slightly different (simpler?) method
I've just carried this out on mine. I did it a fraction different:
Use a chisel tip on a soldering iron and melt the edges of the plastic lugs that hold the cap to the plate. Replace the seal as shown, I didn't push it fully home so that it sealed a bit further down the shaft on an undamaged section as someone else has recommended. Carefully push the cap back in place and remelt the lugs to fix it back in place - no need for screws.
Post #549369 4th Apr 2020 4:24pm
Danwilderspin
Any ideas I’ve taken it apart and reassembled about 10 times - filled this to the letter on my 07 4.2 but it still leaks from the same point albeit less. I bought two seals even and took the original out and put two of the new ones stacked still leaks.
Do you put grease on the shaft tried with none and a little bit didn’t make much difference? Do you lightly sand the shaft as mine is covered in brown crap? Any other ideas?
Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #573477 19th Nov 2020 7:17pm
D3Jon
I'd say lightly sand to remove any abrasive crud AND use some rubber grease.
Normal grease will kill the seal unless it's made of nitrile rubber.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #573495 19th Nov 2020 8:48pm
Danwilderspin
I normally use Vaseline on seals would you recommend or not? I’ll give it a go tomorrow eve had enough now lol Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #573509 19th Nov 2020 9:32pm
Danwilderspin
Cleaned it all out but the is a groove around the base is this normal? I have resort to pu sealant to try and seal the outside of the seal
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #573717 22nd Nov 2020 8:39am
Danwilderspin
Ok so I put put glue around the outside of the seal between the casing in case it was leaking there and also the back where the four screws go in up put a bead down and it seems to have cured it Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #573761 22nd Nov 2020 7:56pm
Ianb4310
Great write up !!
I’ve just done this and fixed my leek but now my rear wiper sets off in the wrong direction any ideas anyone??
Post #585552 27th Feb 2021 3:45pm
Greg66
2006 Range Rover Supercharged 4.2 SC V8 Santorini Black
Really useful thread.
I’ll throw in my 2p.
I asked the garage to check the rear wiper wash as no fluid was coming out. I got the car back with the motor leaking from where the tube joins it, and possibly from that nipple too. Great. The garage explained that they’d flushed the lines and gunk was probably now in the motor and I’d need a new one. Well done lads. Your Censored up, my bill.
I took it away determined to fix it.
I took everything apart, replaced the washer and reassembled per the instructions on page 1. Relatively easy job, doesn’t need 3+ hands or special tools.
The bloody joint still leaked, and the flow of fluid onto the rear windscreen was patchy. Hmm.
So PTFE’d the plastic that the pipe slides onto and tried again. Leak fixed but still poor flow.
Next: remove the cap on the base of the wiper arm, and run the wash wipe. Good fierce flow.
The culprit was the cap. It took a few minutes with a pin and some flowing hot water to clear whatever was in there blocking the nozzles, but that was, I suspect, the root cause. The blockage built pressure back into the tube causing the weakest link to weep.
So: try a thorough leak of that cap and the nozzles before going further. You still have to remove the roof spoiler but that’s a very easy job. Range Rover 4.2 SC
AM V12VS
Porsche 991.1 Turbo S
Mini JCW conv
Post #600035 8th Jul 2021 11:47am
Digger
United Kingdom 2009 Range Rover Westminster TDV8 Mariana Black
Excellent advice
Brilliant advice... I took it one stage further and removed the damaged oil seal from the plastic housing (exactly the same size), added another 10mm washer for good measure and then sealed the join between the plastic and metal with Fernox FX plumbers pressure sealant for good measure. No gaps and no leaking... yet.
Post #613738 24th Nov 2021 10:59pm
Mikeerhymes
Has anyone tried this on a MY11 before I start stripping it down? I have the internal leak out of the motor shaft.
It looks like the part number changed to LR010920 for 2009+
Post #655048 29th Jan 2023 11:59am
alfheim
Norway 2005 Range Rover Vogue 4.4 V8 Adriatic Blue
Does any one know if the same fix can be applied to the headlamp wiper of the pre 2006 model? Seem to have a very similar problem, and washer fluid typically leaking all over the place, though obviously not going inside so less of a problem, but still probably corrodes the mechanism.
thanks
Post #670925 10th Aug 2023 7:41pm
Page 5 of 5 <12345
