![]() | Home > Maintenance & Mods (L322) > Rear washer leak repair - the cheaper option! |
FrankN Member Since: 11 Feb 2017 Location: Vellmar, near Kassel, middle Germany Posts: 101 ![]() ![]() ![]() |
@wayneg
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 544 ![]() ![]() ![]() |
Unfortunately I've left it too late to do this fix and the wiper motor is now totally furbared so it's going to have to be replaced. However, I've noticed that the rear washer pump no longer seems to work. Is there a defeat device that would prevent the washer motor from working if the wiper doesn't work? Fuses are ok. Drives:
Hello Mark ;
ian_w Member Since: 12 Jul 2015 Location: Towcester Posts: 1 ![]() ![]() ![]() |
I've just carried this out on mine. I did it a fraction different:
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
Any ideas I’ve taken it apart and reassembled about 10 times - filled this to the letter on my 07 4.2 but it still leaks from the same point albeit less. I bought two seals even and took the original out and put two of the new ones stacked still leaks.
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 499 ![]() ![]() |
I'd say lightly sand to remove any abrasive crud AND use some rubber grease.
I normally use Vaseline on seals would you recommend or not? I’ll give it a go tomorrow eve had enough now lol Current stable:
Cleaned it all out but the is a groove around the base is this normal? I have resort to pu sealant to try and seal the outside of the seal
Ok so I put put glue around the outside of the seal between the casing in case it was leaking there and also the back where the four screws go in up put a bead down and it seems to have cured it Current stable:
Ianb4310 Member Since: 21 Sep 2017 Location: Gainsborough Posts: 201 ![]() ![]() |
Great write up !!
Greg66 Member Since: 10 Nov 2010 Location: London Posts: 84 ![]() ![]() |
Really useful thread.
Digger Member Since: 24 Nov 2021 Location: Stoke Hammond, Buckinghamshire Posts: 1 ![]() ![]() ![]() |
Brilliant advice... I took it one stage further and removed the damaged oil seal from the plastic housing (exactly the same size), added another 10mm washer for good measure and then sealed the join between the plastic and metal with Fernox FX plumbers pressure sealant for good measure. No gaps and no leaking... yet. |
Mikeerhymes Member Since: 01 Sep 2018 Location: Manchester Posts: 25 ![]() ![]() ![]() |
Has anyone tried this on a MY11 before I start stripping it down? I have the internal leak out of the motor shaft.
alfheim Member Since: 14 Oct 2022 Location: Oslo Posts: 2 ![]() ![]() ![]() |
Does any one know if the same fix can be applied to the headlamp wiper of the pre 2006 model? Seem to have a very similar problem, and washer fluid typically leaking all over the place, though obviously not going inside so less of a problem, but still probably corrodes the mechanism.
