Home > My Range Rover > My L322 Project |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
As I have documented this on FB, I thought I could transfer it over to here and maybe someone can make use of the inspiration.
16th Nov 2021 10:10am |
Next day and I popped to LR parts to get some key shells to replace the manky old keys.
16th Nov 2021 10:19am |
My new straps arrived later that day so I set about replacing them. The old bolts had to go too.
16th Nov 2021 10:25am |
Next job was to replace the brake fluid as it looked a little dark for my liking and I always intended to replace all of the fluids anyway as I always do this as matter of course on a second hand car.
16th Nov 2021 10:31am |
Had a nice delivery the next day so you can imagine what is coming next.
16th Nov 2021 10:44am |
Today I addressed the knocking from the front suspension, the previous owner changed the drop links as that was the cheapest and easiest thing to change, but that did not cure it.
16th Nov 2021 10:51am |
Delivery!
16th Nov 2021 10:52am |
BIGMAMMA Member Since: 28 Oct 2012 Location: LEICESTERSHIRE Posts: 175 |
Really enjoying your story! keep going, you'll have a total refurb soon!!!! '17 RANGE ROVER L405 SDV8 AB LOIRE BLUE with INDUS SILVER ROOF
16th Nov 2021 11:08am |
Nice new oil pan and underneath is 8 litres of Lifeguard 8 gearbox oil
16th Nov 2021 11:25am |
Wheelnuts. They're not the greatest design. They seem to be a normal high tensile steel covered by a chromed steel jacket. I think the core must corrode over time and that causes the chromed jacket to swell and then getting your 22mm socket over is next to impossible.
16th Nov 2021 3:46pm |
Front brakes next.
16th Nov 2021 3:53pm |
I drew some of the PAS fluid out to have a look at it and it looked very different to the new fluid. I thought it was time to protect the PAS components and get it changed.
16th Nov 2021 4:08pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4307 |
Brilliant! Keep them posts coming!
16th Nov 2021 5:14pm |
t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114 |
Brilliant write up |
16th Nov 2021 7:53pm |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
Excellent write up!
16th Nov 2021 8:00pm |
