Home > Maintenance & Mods (L322) > P0171 on 2006 Supercharged |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 588 |
You need a tool like the iidtool to reset the engine adaptations. Range Rover 4.2 Supercharged 2006
22nd Jun 2021 3:14am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Sorry I meant the pcv front left of the engine forgot the word!
22nd Jun 2021 8:05am |
RR_supercharged_702 Member Since: 20 Jun 2021 Location: Las vegas Posts: 18 |
Ty
22nd Jun 2021 7:47pm |
So I did the filter in tank too forgot that but that in theory would give you faults on both banks same with the pump… you could have bad injectors could try and clean? Have you got diagnostics like iid tool to look at the fuel trims Current stable:
22nd Jun 2021 8:17pm |
iid tool is not cheap, can look into another scan tool that might do the job too
22nd Jun 2021 11:10pm |
I think JLR recommend running a rich mix of bg22k Current stable:
23rd Jun 2021 8:25pm |
Jlr doing a rich mix? What is that |
24th Jun 2021 6:34am |
Don’t have much gas in your tank and run a can of bg22k in your fuel tank Current stable:
24th Jun 2021 8:05am |
Bg44k sorry Current stable:
24th Jun 2021 8:08am |
Bg44k will get that,
24th Jun 2021 10:19pm |
I’m not sure anything is possible if the system isn’t sealed - I’d buy a new filter and change it and while you are there take the pump cover off and reseat it Current stable:
24th Jun 2021 11:00pm |
Update still p0171 so I'm saving up to purchase a new fuel pump system and if that doesn't work still then a new o2 sensor from atlantic British ill keep you updated for other RR owners
5th Jul 2021 9:20pm |
Don’t want to sound negative but if it was fuel pump wouldn’t it give the fault on both banks? Current stable:
5th Jul 2021 11:01pm |
Still trying to save up for a part, but it's all good with the negatively but I replaced everything I can think of from both cat and o2's both banks upper and lower and did a smoke test lucky no signs of leak and Pcv replaced to and gas cap, what else am I missing? Sad day in the hood for my RR btw you know any body that wants to buy a
25th Aug 2021 3:57pm |
