Home > Maintenance & Mods (L322) > P0171 on 2006 Supercharged
Page 3 of 4 <1234>
RR_supercharged_702
United States 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
@Danwilderspin
#Also the concertinas between the air coolers and charger plate - both leaking
Where is this im having a difficult time I found the rest you mentioned
Ty
Post #598340 22nd Jun 2021 1:41am
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
You need a tool like the iidtool to reset the engine adaptations. Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #598341 22nd Jun 2021 3:14am
Danwilderspin
Sorry I meant the pcv front left of the engine forgot the word!
Adaptations can be cleared with iid tool or sdd Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #598348 22nd Jun 2021 8:05am
RR_supercharged_702
Ty
So just did a smoke test and the result came back nuthing no leak, that's crazy so I did told the mechanic that when I 1st got the car I wanted to experience the HP on this but I notice the on the freeway while full throttle the car sputtered or bogged im thinkingbits the fuel pump or fuel filter and thoughts that could pop up the code P0171?
I appreciate all the replies its helping me and hope others too
Post #598414 22nd Jun 2021 7:47pm
Danwilderspin
So I did the filter in tank too forgot that but that in theory would give you faults on both banks same with the pump… you could have bad injectors could try and clean? Have you got diagnostics like iid tool to look at the fuel trims Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #598419 22nd Jun 2021 8:17pm
RR_supercharged_702
iid tool is not cheap, can look into another scan tool that might do the job too
iCarsoft LR V3.0 for Land Rover/Jaguar Diagnostic Tool with auto VIN/Quick Test/Actuation Test
And is there a way to clean the fuel injectors with removing them the block
Post #598430 22nd Jun 2021 11:10pm
Danwilderspin
I think JLR recommend running a rich mix of bg22k Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #598522 23rd Jun 2021 8:25pm
RR_supercharged_702
Jlr doing a rich mix? What is that
Post #598540 24th Jun 2021 6:34am
Danwilderspin
Don’t have much gas in your tank and run a can of bg22k in your fuel tank Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #598549 24th Jun 2021 8:05am
Danwilderspin
Bg44k sorry Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #598551 24th Jun 2021 8:08am
RR_supercharged_702
Bg44k will get that,
Oh so when I 1st got the car I was so stoked that I'm gonna put full tank on gas bit after realizing under the car it was over flowing of gas, so I think the previous owner replace the fuel pump but didn't set the gasket properly, you think that could cause the p0171 and causing the fuel pump to go bad or to much air in the fuel system that cause it to sputter or bogged during full throttle
Post #598653 24th Jun 2021 10:19pm
Danwilderspin
I’m not sure anything is possible if the system isn’t sealed - I’d buy a new filter and change it and while you are there take the pump cover off and reseat it Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #598658 24th Jun 2021 11:00pm
RR_supercharged_702
Update still p0171 so I'm saving up to purchase a new fuel pump system and if that doesn't work still then a new o2 sensor from atlantic British ill keep you updated for other RR owners
Thanks
Post #599743 5th Jul 2021 9:20pm
Danwilderspin
Don’t want to sound negative but if it was fuel pump wouldn’t it give the fault on both banks? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #599748 5th Jul 2021 11:01pm
RR_supercharged_702
Still trying to save up for a part, but it's all good with the negatively but I replaced everything I can think of from both cat and o2's both banks upper and lower and did a smoke test lucky no signs of leak and Pcv replaced to and gas cap, what else am I missing? Sad day in the hood for my RR btw you know any body that wants to buy a
Ksport coils overs it's for a sport 05-12 non supercharged
Post #604753 25th Aug 2021 3:57pm
Page 3 of 4 <1234>
