![]() | Home > Maintenance & Mods (L322) > P0171 on 2006 Supercharged |
RR_supercharged_702 Member Since: 20 Jun 2021 Location: Las vegas Posts: 18 ![]() ![]() ![]() |
Blowing exhaust before o2? Cracked manifold? Anyway I can find that out?
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Update on my 06 rr supercharged, I just installed brand-new cat on the driver side and 2 upstrream o2 sensor and the issue remains the same ugh, im really pulling off my hair, so I'm doing some search again p0171 I've check almost everything that involves with that cold except fuel related, can someone point to me where the fuel regulator is actually located? And I'm finally going to try that fuel cleaner, any recommendations would help me save this RR please thank you |
Have you tried smoke machine in the exhausts and intake looking for leaks? Current stable:
I have a smoke machine myself and found nuthing so I thought I'm doing it wrong and so I still brought it to a shop and they also found nuthing too but back then I 1st got the car I filled up the gas all the way and I notice gas was gushing out of the underneath my car, so I never paid attention to it but the code keeps coming back to p0171 and I completely swapped out new parts, except fuel related so I'm gonna start with replacing the fuel pump seal or oring,
Have you tried plugs and coils that side? AFAIK if you are in front of the bonnet with the engine cover off it’s toward the rear on the right - there is a vacuum hos coming from the supercharger piece to it and it had a plug on it a small cube i think Current stable:
P0171 it's telling me the fuel filter and fuel pump could cause this code.
Just replaced the fuel pump but check engine remains
strongstuff Member Since: 26 Jun 2019 Location: North Wales Posts: 44 ![]() ![]() ![]() |
Do you have a friend with a similar car?
What a petrol cap? |
The cap that you undo to fill with fuel. 2008 L322 4.2 V8 SC Stornoway Grey
Oh mine is brand new from the dealership |
Ah, it's not that then |
Did you fix this? I’m getting issues again now so I’m back on This path - the fuel pressure sensor is under the bonnet on the right has a vacuum hose and a plug going to it Current stable:
