![]() | Home > Technical (L322) > 2012 4.4tdv8 electrical problem |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Does sound like an alternator problem. BUT, anything give you a clue berforehand?
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 217 ![]() ![]() ![]() |
Interior lights should be fuse 57 behind glovebox. |
longd Member Since: 24 Oct 2020 Location: West Midlands Posts: 95 ![]() ![]() ![]() |
I checked fuse 57 and it is perfect !! when I pull it I loose the rear interior light and glove box light !!
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
pull out the BMC connector on the negative terminal and check, this disables the smart charging function. If it charges @13.5 volts then further investigation is required else alternator SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC New Toy: Unimog U1550L/37 New : G350D |
without sounding like a |
I pulled the BMC Connector from the negative terminal ,Still no charge at all!!
Sounds like the alternator then SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
Yup I believe you are right!!! I had a quick look at the where the alternator is located …. looks like a mega ball ache to get to !!! I assume the fan etc all has to come out as I don’t see any other way to get access!!! I’ll have a look at the wiki to see the Manual ! Thanks so much for the help guys !! On a side note which way does the fan nut undo ? On uk car does it undo towards the passenger side or drivers side ? |
Awesome link !! Thanks so much |
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 ![]() ![]() ![]() |
HI, worth checking that the one way clutch inside the alternator pulley hasn't failed. THe alternator will not charge very well if it is coasting. I had this happen on a non-charging wife's Polo once. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2567 ![]() ![]() ![]() |
IIRC the pulley is a fixed version. A son shoe-horned a new 4.4 TDV8 alternator to his 3.0 TDV6 D4 and had to fit a free-wheeling pulley for the TDV6. |
Just waiting on hose clip pliers to come and will pull out the Alternator. Will report back my findings |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
Not sure how easy it is to get to live feed from alternator but if not too bad could you not just disconnect, isolate and insulate the wire , recharge the battery and see if any drain? This would definitely confitprm if you have a dead c short in the alternator before you have to remove and change it. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
