Home > Technical (L322) > 2012 4.4tdv8 electrical problem
longd
What an absolute ballache of a job to get the alternator out !!
Honestly , wouldn’t be so bad on ramps but on a driveway absolutely doable but a pain in the arse !!
Have the alternator out and bench tested it , it’s barely putting out one volt, so thankfully it is the alternator that’s the problem , I’d be so Censored off if I pulled it out and it was working fine 😂
Has anyone successfully rebuilt one of these denso dan1110 alternators ?
Don’t fancy spending 300 quid on a new one !
Thanks for al the help so far !!
Ps the viscous fan is left hand thread so clockwise to loosen for future lurkers 🙃
Post #604292 20th Aug 2021 7:09pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Hi, £194 on Amazon. I would look for a regulator and brush pack. Have you checked the Battery control unit is working OK?
I believe the Alternators are Machine sensed. I would also get a drop test done on the battery as well. Replace the bearings as well if a bit lumpy. Check the diodes for reverse current. Brushes get too short and one gets no current to flow. How did you bench test the alternator? I thought you had to spin them at 6000 revs into a load to do that. In the days of Lucas, king of darkness I used to take a dud alternator to Brighton to get it tested on the machine at Lucas HQ.
Post #604297 20th Aug 2021 8:14pm
longd
Don’t suppose anyone knows where this is supposed to be routed
Post #604583 23rd Aug 2021 3:36pm
longd
Post #604589 23rd Aug 2021 4:47pm
