![]() | Home > Technical (L322) > Intermittent Starting Issue - L322 4.4 v8 Any Ideas ? |
ochaffard Member Since: 13 Jul 2021 Location: Paris Posts: 1 ![]() ![]() ![]() |
I had the same issue... thee starter internal contacts are the guilty ones. I changed the starter and everything is fine. Known issue for the 2010-12 4.4 diesel |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
I have a new Starter by the way, but continue to have intermittent starting issues:
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2652 ![]() ![]() |
A known issue is the trigger wire from the starter relay to the starter solenoid not being able to carry enough current to cause the solenoid to be operated with sufficient force to hold less than perfect contacts closed. The wire is over 6m long, half of which is 4mm2 and the other half 2.5mm2. People have found that installing a replacement wire between the relay and solenoid overcomes the starter malfunction. A new starter will also overcome the problem while the contacts are in good condition. |
Makes sense, is it a new part code or another piggyback wire? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
Not a LR fix, just a length of appropriate gauge wire fitted with the required terminals. |
Have cleaned the busbar and the mega fuses, they all seem to have some oxidation. Also found some oxidation CJB earthing point.
New Toy: Unimog U1550L/37 New : G350D |
braystacey Member Since: 07 Aug 2021 Location: St Albans Posts: 3 ![]() ![]() ![]() |
I have a similar issue.
Mine seems to be behaving since i did the cleanup work, bad supply/earth to JBC/BCM can explain all of the issues i was having. Car is cranking @ low voltage even. Residue build up seems inevitable due to age and use.
Burkie33 Member Since: 11 Aug 2021 Location: Dunoon Posts: 20 ![]() ![]() |
Afaik, did you manage to rectify the problem……..I am having the same issue currently…… I see you are in Derby, great town…….I used to live in Burton |
Hi, will you please help me, I have the same issue but don’t understand what GAP and BCM are…….🙏🙏 |
Hi, has the new starter solved the problem ? 🙏 |
Hi GraemeS, will you tell me the location of the starting relay please 🙏 |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
GAP is the company that make the IID diagnostic tool.
Thank you 🙏 |
