![]() | Home > Technical (L322) > Intermittent Starting Issue - L322 4.4 v8 Any Ideas ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
the L322 has different engines and models so if you fill in your car profile then it will be easier for somebody to help with your problem... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
mine has started to get a hard brake pedal after being left for a few days, there is a microswitch on the pedal, if you press it harder so that the brake lights come on and it still doesnt start then that should discount the idea that the pedal is the issue, if it does start though it could be something to do with the pedal switch.
gotters Member Since: 15 Aug 2015 Location: London Posts: 41 ![]() ![]() ![]() |
was so intent typing up the issue forgot to put my car details in
Afaik there is no connection between the starting circuit and the brake pedal apart from the micro switch. So like mine the pedal is going hard, but possibly too hard to press significantly in yours. There is an interlock which won’t allow the car to start unless the pedal is depressed, the only way the car knows if you’ve got your foot on the pedal is the pedal switch, so if you can’t press the pedal enough, the car doesn’t know you are pushing it, and it won’t start. As you say yours is too hard to press when the starting issue occurs I would check that first.
thanks for the reply - interesting
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 339 ![]() ![]() ![]() |
Do you get the solenoid click?
yes, do get a quite faint tick tick tick when I hold the start button down and it won't start.
First things first.
I had exactly the same problem, click from the solenoid, connect the jump pack and it would start ok. Even leaving it whilst waiting for the breakdown man to arrive enabled it to start.
thanks @millerj90
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
I have the same issue from time to time, looks like there is a linkage to the brake system here.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2643 ![]() ![]() |
The only "sensor" is the brake light switch above the brake pedal which requires the pedal to be depressed far enough to operate the switch, noting that the switch itself could be faulty. If the vacuum assist has been depleted then the pedal may need to be pushed quite hard to move the pedal far enough away from the switch plunger. |
I hope thats all it is. Have a new switch coming today, will pull the old one apart and have a look. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
I carry a spare switch after the problematic D3/D4 switch, although the L322 switch doesn't appear to fail much at all. |
