Home > Technical (L322) > Intermittent Starting Issue - L322 4.4 v8 Any Ideas ?
Page 2 of 3 <123>
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
Thats why it makes me thing there are some other dependencies. Any ways newone installed, wait and see what happens. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #601443 22nd Jul 2021 7:21am
ochaffard
France 2012 Range Rover HSE TDV8 Buckingham Blue
I had the same issue... thee starter internal contacts are the guilty ones. I changed the starter and everything is fine. Known issue for the 2010-12 4.4 diesel
Post #602010 27th Jul 2021 6:55pm
ffrr14
I have a new Starter by the way, but continue to have intermittent starting issues:
There is a known BCM issue LTB00492NAS2 | https://static.nhtsa.gov/odi/tsbs/2014/SB-10071055-6903.pdf
I have done up update through GAP, lets see if it helps else BCM swap. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #602047 28th Jul 2021 3:44am
GraemeS
Australia
A known issue is the trigger wire from the starter relay to the starter solenoid not being able to carry enough current to cause the solenoid to be operated with sufficient force to hold less than perfect contacts closed. The wire is over 6m long, half of which is 4mm2 and the other half 2.5mm2. People have found that installing a replacement wire between the relay and solenoid overcomes the starter malfunction. A new starter will also overcome the problem while the contacts are in good condition.
Post #602063 28th Jul 2021 10:50am
ffrr14
Makes sense, is it a new part code or another piggyback wire? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #602077 28th Jul 2021 12:44pm
GraemeS
Australia
Not a LR fix, just a length of appropriate gauge wire fitted with the required terminals.
Post #602134 28th Jul 2021 10:47pm
ffrr14
Have cleaned the busbar and the mega fuses, they all seem to have some oxidation. Also found some oxidation CJB earthing point.
New : G350D
Post #602546 1st Aug 2021 11:12pm
braystacey
United Kingdom 2011 Range Rover Vogue 4.4 V8 Galway Green
I have a similar issue.
Turn on the ignition and everything seems fine. Entertainment system comes on, all good. Then the tick-tick-tick when the engine should be turning over and the hard brake pedal.
Added to that though is a reset of the entertainment system with the date back to 2009 and the analogue clock buzzing round like I've just hit 88mph. Then there is further clicks and whirs from behind the screen.
Is this electrics issue consistent with others' experience or does that sound something new?
(Apologies if I've got anything wrong, first RR and first post on this forum.) 2011 Vogue 4.4 TDV8 Galway Green
2022 Evoque Portofino Blue (Mrs braystacey’s)
Post #603102 7th Aug 2021 2:33pm
ffrr14
Mine seems to be behaving since i did the cleanup work, bad supply/earth to JBC/BCM can explain all of the issues i was having. Car is cranking @ low voltage even. Residue build up seems inevitable due to age and use.
Light emery paper application and crc contact cleaner did the job for me.
New : G350D
Post #603157 8th Aug 2021 12:18am
Burkie33
northernmonkeyjones wrote:
Afaik there is no connection between the starting circuit and the brake pedal apart from the micro switch. So like mine the pedal is going hard, but possibly too hard to press significantly in yours. There is an interlock which won’t allow the car to start unless the pedal is depressed, the only way the car knows if you’ve got your foot on the pedal is the pedal switch, so if you can’t press the pedal enough, the car doesn’t know you are pushing it, and it won’t start. As you say yours is too hard to press when the starting issue occurs I would check that first.
The thing making the pedal hard is the bleed off of vacuum in the brake Servo afaik.
Afaik, did you manage to rectify the problem……..I am having the same issue currently……
I see you are in Derby, great town…….I used to live in Burton
Post #603455 11th Aug 2021 11:30am
Burkie33
Hi, will you please help me, I have the same issue but don’t understand what GAP and BCM are…….🙏🙏
Post #603458 11th Aug 2021 11:33am
Burkie33
Hi, has the new starter solved the problem ? 🙏
Post #603459 11th Aug 2021 11:34am
Burkie33
Hi GraemeS, will you tell me the location of the starting relay please 🙏
Post #603460 11th Aug 2021 11:42am
Dolphinboy
GAP is the company that make the IID diagnostic tool.
BCM is the Body control module which should be under your pax seat and controls a number of functions in the car. they are known to go faulty at times.
Post #603473 11th Aug 2021 1:05pm
Burkie33
Thank you 🙏
Post #603487 11th Aug 2021 3:23pm
Page 2 of 3 <123>
