![]() | Home > Maintenance & Mods (L322) > Oil removal 4.4L TDV8 |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 814 ![]() ![]() |
Out of curiosity what’s the risk when driving overfilled?
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Correct on bonnet up process Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Rob,
Service sheets in Wiki under Info at bottom. 3 types for the 4.4 on a rolling basis. Basically more filters every 2 years then pollen and oil on other one. Adjust handbrake annually. Coolant and brake at every x years etc. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Thanks Rob,
Update:
Rob,
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1261 ![]() ![]() |
Baltic Blue, is that a high pressure sealing rag wrapped around that tube? |
Thanks Mike! Will do |
Mine arrived yesterday, influenced by these threads Thanks |
https://services.totalenergies.uk/too-much-oil-car 2018 SE SDV8 4.4 Byron Blue |
You won’t regret the cost Kot, it soon pays dividends, and the peace of mind knowing that it has got the correct type and quantity of oil in the sump is priceless.
