![]() | Home > Maintenance & Mods (L405) > Adding Timed/Remote Climate to 2017 model - it can be done |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
put into the wiki next to the 2014 version..thanks. |
spbee Member Since: 25 Jul 2021 Location: Cumbria Posts: 34 ![]() |
'Antenna for receiver (a glass mount 433MHZ antenna with Fakra I type connector will work)'
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 230 ![]() ![]() ![]() |
Unfortunately I can't remember where I got the antenna from. It doesn't need to be a type I connector, a type Z (universal) will also do the job. I used a type I as I wanted to to match the connector on the receiver.
great TYVM |
Last question i promise!
Connector body is Landrover part no YPC915820, it is made by TE Connectivity (Tyco) I think part number 1355082-3 but most suppliers seem to only do them with minimum order 1000+ The connector inserts I used were ones I had at work that fitted, I believe the Tyco part number for these is 5-928999-5 for wire size 0.25-0.35mm2 or 5-963715-5 for wire 0.3-0.5mm2 |
brilliant thanks for your help.
All done and tested on my 2015 |
this also works for pre 2017 vehicles |
