Home > Technical (L322) > Where does this go??
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Thanks guys, rather chuffed with myself if I'm honest. As this is my first ever V8 it's rather daunting finding your way around the engine finding out where everything is compared to the standard 4 cylinder cars and the V6 cosworth I once owned. Next job is a nice big service that's booked in for the end of next week, going to have all the oils changed on everything except the gearbox. Expensive maybe, but piece of mind.
Post #598904 27th Jun 2021 10:33am
dingg1
Get the gearbox oil change done as well, unless its just been done, I wouldn't reset adaptations it may lead to issues.
Post #598905 27th Jun 2021 10:54am
Barmybrummie
Hey dingg the gearbox was repaired at midland gearbox specialists in October last year by the previous owner at the cost of £2600 so I would imagine the oil was changed back then. The gearbox is as smooth as it should be so thought I would leave it as it's not broke don't fix it type of thing. Unless another change won't do it any harm? What do you think?
Post #598913 27th Jun 2021 12:44pm
dingg1
Just leave it, it should be good for another 60k miles
Post #598914 27th Jun 2021 12:58pm
Barmybrummie
Well that lasted less than 24 hours, bong and restricted performance came back on. So my next thought, drivers side inlet manifold. Sprayed window cleaner all over it and low and behold it's foaming like a rabid dog all along the inner lip for about 4 inches.
So tomorrow I'm going to drop it off at bucklands in Gloucester. I'm not going to bother trying to repair it, reading up on the repairs on here they don't seem to last long so I'm just going to bite the bullet and get it replaced. Might as well get it serviced while it's there and the oil leak sorted. I fear this is going to cost me an arm and leg. Anybody have an idea what the cost is for the intake manifold supply and fit?
Post #598926 27th Jun 2021 5:33pm
kbald
I replaced mine myself and the manifold was about £350 for the part. I spoke to an indie and they quoted 8 hours labour which came to about £600 if I remember correctly. Not sure it would take 8 hours though if someone knows what they are doing. Current 2007 TDV8 Vogue Buckingham Blue
Post #598930 27th Jun 2021 7:25pm
Click on profile, then scroll down to My Range Rover profile and fill it in, you then get a little Range Rover in your side bar, hover over it and it lets us know what model you have.. Thumbs Up Pete
Post #598932 27th Jun 2021 7:51pm
Barmybrummie
Thought it would be wallet lightningly expensive kbald. I just don't have the time or experience to change it myself so gonna just have to bite the bullet.
I'm confused there Haylands work your reply. Will doing that fix my manifold? Laughing
Post #598942 27th Jun 2021 9:07pm
It'll help us to help you...!!! Pete
Post #598952 27th Jun 2021 10:28pm
Barmybrummie
I thought I'd filled all that out when I joined, sorry.
Post #598953 27th Jun 2021 10:34pm
Barmybrummie
Eventually picked the car up from the Indy this morning, it drives totally amazing since the new intake manifold has been replaced. Must have been like that for a fair while me thinks. Next job, front and rear subframe bushes and steering rack. Is it an easy job changing the subframe bushes?
Post #600627 14th Jul 2021 2:26pm
