Home > Technical (L322) > Where does this go??
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Hey guys I've been getting black soot under hard acceleration so decided to check the top IC hoses which don't have any splits in them. I then found this pipe hanging loose down the right side of the engine which comes from along the top engine. I've had a look and then found another loose pipe which you can see in pic 3 (I moved it there so I could take a pic) which goes down to the right side of the engine. Any ideas where these pipes connect to? Your help will be much appreciated.
Post #598526 23rd Jun 2021 9:39pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
I take it this is a 3.6TDV8. It certainly looks like it, but if you add the detail to your profile, people will know in future.
The pipe in the top picture should be plugged into a short stub on the rear of the air filter housing, so I doubt it’s doing anything vital. You can just about make it out in the picture below.
I can’t really tell where the pipe in pic 3 should be going; could be anywhere really and I can’t immediately see a comparable pipe on my car. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #598580 24th Jun 2021 12:15pm
Barmybrummie
Thanks for that Steve. I did actually think it pushed on that nipple but when I took the air filter out I couldn't see a hole inside the air box so thought maybe not in that case I will push it back on and try and find where that other pipe supposed to go. And yes it's the 3.6 tdv8. I wonder if that would cause black soot then when im flooring the accelerator. Turns out I've also just noticed an oil leak coming from the back of the engine somewhere. It's dripped all down the steering rack into the driveshaft and various other suspension components, will need to check that out the weekend when I get back to the UK. Any idea where the norm is for it to leak around there?
Post #598598 24th Jun 2021 3:37pm
Barmybrummie
Well well well now that is strange. I pushed that hose on to the nipple on side of air box, all was fine until I got on the motorway last night, floored it and the car went straight into limp mode with message engine fault no eml. Just managed to crawl into services, plugged in the gap and fault said intake manifold valve stuck in closed position. Reset fault and carried on with my journey, no problem for about an hour then same again. This time I just turned engine off, restarted and continued and then same thing again half hour later. It only seems to do it when I put my foot down, not hard but gently I dare not floor it hard. So I then took the pipe off the nipple and connected it to the other pipe that was hanging loose and now all seems fine again. I'm beginning to wonder if there is some problem with vac hoses being attached in the wrong places. Before i bought the car, the owner took it in to replace manifold gasket and it was a body off jobby because they snapped 2 bolts. I'm wondering if they didn't put it all back together correctly. Looks like it's going to be a long afternoon fault finding me thinks after the qualifying. Anybody have any ideas where to start?
Post #598835 26th Jun 2021 10:25am
mjdronfield
Body off? Can’t do that with the L322, it’s monocoque.
Sounds like you are on to something though.
Hope you get there in the end....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #598841 26th Jun 2021 11:31am
Can't help with your pipe issue but you can't take the body off an L322 Range Rover, they are a monocoque design. Someone is telling your porkies....
Edit... Mark types quicker than me..!! Pete
Post #598842 26th Jun 2021 11:34am
Barmybrummie
Thanks guys. Oh dear that's what was told to the previous owner. But then I've been told by various others that the body has to come off when changing the turbos on L322's or is it engine out on these, totally confused now.
Hopefully I can find where these go sometime today, trouble is there not much room, need hands like Mr tickle to get to some places in the engine bay.
Post #598844 26th Jun 2021 11:44am
mjdronfield
The L322 does not have a separate chassis. There are front and rear subframes that hold the suspension etc, which may confuse folk.
Most people seem to strip all the front off to get in to the depths of the engine, from what I can tell anyway.
The Sport has a separate chassis..... it might be that what people are confusing it with too.
I’m normally the one typing too slow Pete, makes a change 🤣.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #598845 26th Jun 2021 12:02pm
Barmybrummie
Right guys after a quick inspection after taking the air filter housing off I came across a few things that are not right. First of all, the housing wasn't positioned correctly into the big round rubber grommet that goes into the wing for the air intake (pic 1).
Secondly the front first air outlet was fitted at an obscure angle and crushed with the jubilee clip so that could be letting in unmonitored air.
And thirdly, in pic 2 there's like a small chamber with an electrical plug on it just behind the air outlets under oil filler tube with a vacuum hose plugged in underneath but on the side there is a small nipple that looks rather clean as if something has been fitted on it. I'm thinking that small hose should go on it.
And fourthly there are 2 bolts missing that should securely attach to the first plastic downpipe. See pic 3.
Whoever put this back together was either incompetent or in a rush.
Post #598847 26th Jun 2021 12:24pm
Barmybrummie
Pic 1 where they crimped the pipe to the air housing.
Pic 2 is the nipple on that chamber that's rather clean.
Post #598848 26th Jun 2021 12:33pm
If you download the Workshop Manual from the Wiki it will have diagrams showing where all the pipes go, it might take a while to find them but they will be there.... Thumbs Up Pete
Post #598850 26th Jun 2021 1:08pm
Barmybrummie
Thanks Haylands. I've connected all the pipes and tubes properly and securely and where I believe they should all fit so I think that should solve the problem. I will take it for a spin down the A38 after the qualifying and let you know.
Thought I would wash out the inside of the air box considering it was out.
Post #598854 26th Jun 2021 1:39pm
Barmybrummie
Put everything back together, all the hoses in the correct places and just took it for a spin and woooooooow what a difference it's made. Acceleration is so much more better and far more smoother, absolutely flew when I put my foot down, so much more responsive. And I'm getting nowhere near as much black soot out the exhaust under acceleration, still a little bit but not clouds, hopefully this will cease after a short time of driving it. I was getting an average of 27.6mpg at a steady 75 so I wonder if I'll get better mpg now.
So I've been driving the car since I've owned it just over 2 months like this and just knew something wasn't quite right and now feels like a different car.
Thanks for your help gentlemen.
Post #598867 26th Jun 2021 5:09pm
That's great news, glad it's fixed and running well... pat yourself on the back for sorting it... Thumbs Up Pete
Post #598882 26th Jun 2021 8:13pm
mjdronfield
Nice one. A good days work......
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #598899 26th Jun 2021 11:35pm
